Pages: 1 [2] 3  All   Go Down
Author Topic: Whats the best V6?  (Read 7214 times)
Re: Whats the best V6?
« Reply #15 on: 24 July 2010, 04:41:07 »
access to the left hand coil pack and plugs is none too easy on a 3.2. :(
neither of the ex plod 3.2s that i've owned have had egr valves :) makes them a bit less complicated i guess. :-/
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #16 on: 24 July 2010, 07:20:35 »
What are the differances between 3.0 and 3.2 manifolds ?
Easiest way to describe the difference is 2.5/3.0 manifolds are heavy cast steel which are quiet restrictive, where as the 2.6/3.2 are a far lighter tubular looking manifold.
Hope that helps.
« Reply #17 on: 24 July 2010, 10:21:37 »
Not really, and probably easier than 3.0/2.5 :y
« Reply #18 on: 24 July 2010, 10:36:43 »
But taking the ignition system as a whole, i prefer 3.2 as it's one component plus plugs. 2.5/3.0 the dis PAC is a right be-atch  to swap out in comparison, and one less thing to diagnose. I would far prefer to swap out 3.2 dis than a set of leads, but then swapping plugs is a bit more aggro.
barclay03
  • Glasgow
« Reply #19 on: 24 July 2010, 17:10:01 »
DLK - whats required in fitting the 3.2 manifolds?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #20 on: 25 July 2010, 00:47:43 »
Being honest alot of patience mate.
Just the 2.6/3.2 manifolds plus the gaskets make sure you get 2.6/3.2 gaskets else you will be stripping everything you have done. You will need to cut some off the lip of the cat that goes into the manifold .
Hope that helps you :)
barclay03
  • Glasgow
« Reply #21 on: 25 July 2010, 10:17:27 »
Cheers, no major work then, pretty "plug n play"  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #22 on: 25 July 2010, 10:30:26 »
No it is just such a pain I actual prefered to remove the heads on my own  :D
« Reply #23 on: 25 July 2010, 10:32:00 »
Another thread strangely becomes a "sticky" after Daz posts in it  .....
Gremins or "finger trouble" ..  :)
    • E250 Est / Elroq
« Reply #24 on: 25 July 2010, 10:34:49 »
and unstickied again  ;D ;D ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #25 on: 25 July 2010, 10:48:29 »
Eh? why is that then? :-?
barclay03
  • Glasgow
« Reply #26 on: 25 July 2010, 11:03:51 »
Hopefully, the engine that is being worked on will be out of the car anyway, and possibly getting the cams changed... so sure i could work something out ;D
i neglected to change an exhaust gasket on a previous v6 purely because i couldnt be bothered getting into it lol
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #27 on: 25 July 2010, 11:14:58 »
If the engine is out of the car then mate you are laughin :y
All you need is
2.6/3.2 Manifolds
2.6/3.2 Manifold to Head Gaskets
A few Bolts and Nuts incase
2 O ring Gaskets where the CAT joins the Manifold (this is where you will need to grind/cut some off the lip on the CAT)
barclay03
  • Glasgow
« Reply #28 on: 25 July 2010, 12:45:52 »
Thats magic, cheers!  :y
2woody
  • Northumberland
« Reply #29 on: 26 July 2010, 14:06:39 »
Honda NS-X  -  that's the best V6
Pages: 1 [2] 3  All   Go Up
