Author Topic: suspect head gasket?  (Read 2103 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 26 July 2010, 20:09:57 »
think i may know the answer but here goes,
3.0l elite 1998.
loosing coolant, no leaks external at all.
loosing  like a header tank full in 10 miles.
no oil in water.
no water in oil.
not the matrix as no swimming pool in footwell.
runs ok.
idea`s. :-?
Re: suspect head gasket?
« Reply #1 on: 26 July 2010, 20:32:34 »
Any Rough running on initial start up?
Could well be, but I'd be after compression test results first :y :y
The Red Baron
« Reply #2 on: 26 July 2010, 20:34:40 »
not got the car up here yet ld. ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 26 July 2010, 20:44:51 »
A header tank in 10 minutes?  I'd be seeing loads of white smoke if it were HG, wouldn't I?
I'd say it must be a leak, perhaps burning off on the exhaust manifold, so not hitting the floor?
The Red Baron
« Reply #4 on: 26 July 2010, 20:53:40 »
3.0l elite 1998.
no oil in water.
no water in oil.
runs ok.
idea`s. :-?
The Red Baron
« Reply #5 on: 26 July 2010, 20:55:09 »
will have a look around the back of the oil cooler plate when it comes up here.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 26 July 2010, 20:58:50 »
3.0l elite 1998.
no oil in water.
no water in oil.
runs ok.
idea`s. :-?
LOL.  I must learn to read properly.  ;D
« Reply #7 on: 26 July 2010, 21:08:33 »
Might be worth checking the header tank cap and the neck where it screws on .. the cap safety valve can fail so it never pressurises properly , and the neck can develop small cracks that causes the same problem
If the system does not presurise it is running at very nearly boiling point.. so a great deal of evaporation takes place very quickly .. :)  a bit like simmering a pan of water .. :)
The Red Baron
« Reply #8 on: 26 July 2010, 21:17:35 »
good point entwood. :y
