Author Topic: lifting up and out door card  (Read 1782 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 11 August 2010, 09:40:25 »
Have removed all the screws from the door but when i try to lift it up to un hook it from the top of the door frame under the windon can not get it to lift out.
Any tips , was giving it some but did not want to over do it incase i damage something.
Thanks
Steve
Re: lifting up and out door card
« Reply #1 on: 11 August 2010, 09:45:04 »
Have you gone through the guide?
http://www.omegaowners.com/forum/YaBB.pl?num=1152953579
and got all the screws?
SP_3.2
  • Leicester
« Reply #2 on: 11 August 2010, 10:12:22 »
Yep checked all screws all done, just the very  top where the locating Strip is can not get it to pop out the lift the card out.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 11 August 2010, 15:44:03 »
Are you sure you've removed the 'secret' screw in the facelift guide?
Should be able to thump it with the palm of your hand at the bottom.
« Last Edit: 11 August 2010, 15:45:23 by Auto_Addict »
I like red cars
SP_3.2
  • Leicester
« Reply #4 on: 11 August 2010, 16:53:39 »
Got that bad boy out :y the one just above the pull out door pocket and the one behind the  twitter.
mantahatch
« Reply #5 on: 11 August 2010, 16:58:45 »
Funnily enough I have just done this today to get at my door strap.
I found it was just held extremly tightly on the top edge. It was a case brute force with a lot of care.
But I did make sure all cables and screws where disconnected first.
HTH
« Reply #6 on: 11 August 2010, 17:18:00 »
provided the door card will angle out at the bottom to get a good grip on the bottom edge it is just a case of lifting the card directly up. Some brute fource is needed, and you may find the black clip strip will break away from the door card. Glue and short self tappers fix that.
SP_3.2
  • Leicester
« Reply #7 on: 11 August 2010, 19:53:45 »
Cool thanks all for the tips will give them a go :y :y.
