Author Topic: Estate back box  (Read 2194 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Estate back box
« on: 23 August 2010, 19:29:50 »
Is the back box on the 3.0ltr estate the same as on the 3.2ltr estate :-?
    • E250 Est / Elroq
Re: Estate back box
« Reply #1 on: 23 August 2010, 21:52:43 »
DBW backboxes are a little longer.
All GM supply are the longer ones now iirc
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Estate back box
« Reply #2 on: 23 August 2010, 22:01:33 »
Are they on trade club and if so how much  :-?
Re: Estate back box
« Reply #3 on: 23 August 2010, 22:17:24 »
Eternal may be a better option...
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Estate back box
« Reply #4 on: 24 August 2010, 04:49:13 »
Can't find a back box for the 3.2 estate on the eternal web site so will have to try and ring them. :-/
Re: Estate back box
« Reply #5 on: 24 August 2010, 09:41:47 »
They'll tell you they don't do one, but the 3.0 one they list will fit. Tail pipes might be a little short but some cheap chrome trims will sort that. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Estate back box
« Reply #6 on: 24 August 2010, 09:47:05 »
I thought it was all Face Lift Estates where longer?, Had a Pre Face Rear Box fitted to one my 3.0 MV6 Face Lift Estates, drove my mad on the M1 with the noise being slightly trapped behind the rear bumber.
« Last Edit: 24 August 2010, 09:48:29 by zirk »
Re: Estate back box
« Reply #7 on: 24 August 2010, 09:50:17 »
Correct. I think Eternal only list pre-facelift exhausts hence a 3.0 but no 3.2.
Couple of chrome trim sections from Lidl (IIRC) for 6 quid sorted mine.
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Estate back box
« Reply #8 on: 24 August 2010, 11:44:11 »
I think that whats on mine as the pipe is short and I do have a noise but I found two rubber mounts missing (fitted now) and it has been in contact with the bumper and plastic and heat do not mix.
