Author Topic: ABS ECU change takes me full circle!  (Read 1889 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 09 September 2010, 14:06:51 »
When I joined OOF, not long after its creation, the first real job I tackled was changing my ABS ECU. I bought a secondhand unit off MartinP and it worked fine until recently. I conciously sourced another S/H unit as opposed to refurb from another forum members Lincs Robert (thanks for the speedy despatch).
Fitted it today and yesterday (mostly that day was spent tackling the pink clip which was broken).
The job was fairly straightforward otherwise though I did curse having put all 6 bolts back in. ( I can hear Dbug laughing right now) My new £20 47 piece 1/4 inch drive socket set helped a lot. All I removed was:
the battery, loosened the three multi plug assembly from battery tray, undid the clip from around the power steering reservoir and of course the coolant  top hose. I just don't see the point of taking anything else off.
Today I am a very happy bunny. Since the first ABS ECU I have
changed the gearbox twice(with help thank goodness)
changed the cats
new exhaust
changed the passenger side manifold gasket
rear discs, pads and shoes,
HBV twice
Cambelt and tensioners
DIS pack twice
plug leads
cleaned breathers twice
So I am now wondering what will go next on the cycle apart from my back! ;D ;D
Re: ABS ECU change takes me full circle!
« Reply #1 on: 09 September 2010, 14:12:42 »
It looks like you've been reasonably 'Blessed' so far Varche ::)
The old girl has kept you on your toes without having you tear all your hair out (yet!) ;D ;D :y
Sixstring
  • Lydney, Gloucestershire
« Reply #2 on: 09 September 2010, 14:14:08 »
Congratulations!! you have now learned that miggy ownership is a constant replacement cycle of bits.
Seriously, now....think how much you would have paid out if you had to pay a garage to do all that work for you!!
the sources or s/h parts will eventually start to dry up, but luckily for us there is OOF............without it, I really think you would suffer finding a few of the bits to keep them all going!
MartinP
  • Dudley
    • BMW 320D
« Reply #3 on: 10 September 2010, 00:01:34 »
Well done!
my first job was to strip the gear selector switch then replace the 2nd gear soloniod, as well as changing the sluh box oil only to find the problem was a multiplug by the battery not clipped home.
all a good experience though.  :)
Martin
« Reply #4 on: 10 September 2010, 07:38:48 »
I would like someone to rewrite the guide who does this job...
I hear ours is overkill in terms of removal.
« Reply #5 on: 10 September 2010, 19:14:21 »
changed the cats
new exhaust
HBV twice
DIS pack twice
plug leads
 ;D ;D ;D ;D ;D ;D ;D ;D - all six !!!!
All you need to remove :y
