Peugeot 307 cc key prob
Started by hotel21, 15 September 2010, 18:02:19
hotel21
Miss H21 has a 307cc and, to be honest, its not a bad wee car.  She is a teacher and so, fits the persona!
Problem is the spare kay.  Not only does the flick knife blade gubbins not work, it does not lock/unlock on the button presses and neither does the boot release.
Changed the battery and no change.  Key does start the car though but seeing as there is no keyhole for the metal blade, its not a great deal of use as a 'spare'.
Anyone any ideas as to whats what?  The PCB looks ok but I'm no expert in these things.
Martin_1962
iainb
Your JLR dealership should have a RF scanner for key testing,so take the key to work and see if you get a reading.
Quote.... but seeing as there is no keyhole for the metal blade, its not a great deal of use as a 'spare'.  ...
manual key hole is often on our passenger door, it is on SWMBO's Smart & I've seen a key lock on a Renaults passenger door too. I know it not an answer to you problem though  ::)
hotel21
QuoteWhat are the switches like?
Will split the case and take a piccy in the morning.
hotel21
QuoteYour JLR dealership should have a RF scanner for key testing,so take the key to work and see if you get a reading.
JLR Dealership???
Martin_1962
If it is a failed switch you have my address.
hotel21
QuoteIf it is a failed switch you have my address.
Can you test outwith car to ensure all frequencies working?
Martin_1962
I use s scanner an djust listen for the noise
JLR Dealership???
*Cough* Jaguar Landrover *cough*
I'm sure you know of one nearby ::)
hotel21
JLR Dealership???
Its so obvious when its explained to you, isn't it....   :-[
My excuse is the 'J' bit.  We only do the LR here....   ;D
