Author Topic: Chris' new wishbone guide  (Read 3979 times)
« on: 06 October 2010, 11:15:16 »
[split] [link=http://www.omegaowners.com/forum/YaBB.pl?num=1285891052/0#0][splithere][/link][splithere_end]
Cheers for the rewrite Chris  :y
« Last Edit: 06 October 2010, 11:17:52 by jimbob »
Re: Fitting Wishbones and drop links.
« Reply #1 on: 01 October 2010, 02:14:04 »
Ok Jimbob, happy with that, just needs the pics adding .....?
« Reply #2 on: 01 October 2010, 02:32:14 »
14 reads so far, any thoughts before Jimbob moves it? Is it clear and makes sense?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 01 October 2010, 06:01:53 »
i think you have covered all the angles there chris, easy to understand. one point, when re-fitting the wishbone bolts, to remember which way the bolts came out & go back in.
good write up :y
« Reply #4 on: 01 October 2010, 08:59:34 »
As the Baron says ... and a note about the wishbone bolts being different lengths ??
It is a sod when you spend ages and eventually get the vertical bolt in ... only to find you've used the wrong one and have to take the bugger back out and start over ...
been there got the T-shirt ... wasn't funny .. :(
Nice write ups  :y :y :y
The Red Baron
« Reply #5 on: 01 October 2010, 09:07:51 »
good point, forgot that one. :y
« Reply #6 on: 01 October 2010, 09:33:35 »
Ok, edited in those points, Thanks guys.
Anyone know the torque setting for the knuckle pinch bolt and drop link nuts?
« Reply #7 on: 01 October 2010, 09:58:50 »
pics added as I think you want them...
give me the ok and ill put it live  :y
davethediver
  • Blackburn, Lancs.
« Reply #8 on: 01 October 2010, 14:41:23 »
Excellent guide chris, rag in the subframe now that would have been a good idea :-[ :-[
P.A. Caron de Beaumarchais
Welung666
« Reply #9 on: 01 October 2010, 15:53:00 »
Not sure if you want to add in a tip for speeding wishbone fitting up a little?
With the droplink off and steering at full extension on the side you are working on, pull the leg out and fit only the rear (vertical) bush in enough to drop the bolt through from the top, then fit the ball joint into the bottom of the leg and finally the front bush (horizontal) bolt. Turn the steering to  the opposite lock and fit the top drop link nut (easily torqued there (65nm)) then centre the steering and fit the lower end of the drop link. :y
« Reply #10 on: 01 October 2010, 21:31:04 »
how is it quicker? does it make fitting the ball joint easier?
« Reply #11 on: 02 October 2010, 02:18:25 »
Oh ffs, the modify button has gone. I give up. :(
Lower balljoint to knuckle is 100nm/74lbs ft.
Anti-rollbar link rod to strut 65nm/48lbs ft.
Welung666
« Reply #12 on: 02 October 2010, 10:03:00 »
Both sides in just over an hour start to finish, slightly easier to get the nottom ball joint in as the drop link isn't stopping the leg from pulling out so far.
« Reply #13 on: 05 October 2010, 08:46:33 »
The bottom link for budget wishbones doesn't work Chris
« Reply #14 on: 05 October 2010, 19:04:28 »
Working here, although it says product removed wishbones are in a link on the right...?  :-/
