Author Topic: Been down my scrappy  (Read 2187 times)
luv_my_mv6
  • Northwood (London)
  • Just one thing after another
« on: 03 July 2007, 16:18:39 »
Hello guys, im a bit reluctant to post this question as it could lead to problems of the obvious sorts, but down my scrappy, there are 4 omegas, 3 2.0l and one 2.5 or 3.0? The 2.5/3.0 has had the headlights and washers taken, engine gone etc, but my main intrest is the back, the boot is locked, obviously by the c/l and with no battery in the car making it a fortress to get into.... now, I know alot will say go through the doors and put the seats down, but with 2 cars stacked ontop of it, im reluctant to open the doors incase the whole lot comes crashing down on me where the roof support from the doors has gone, is there a way of opening the boot (saloon) by leaning through a window in either the drivers door or front passenger door or by other means? there is also a heavy covering of broken windscreen and side window glass all over the seats, so climbing in via that way is going to be deadly. I dont mind PM if its a bad subject, or if this post needs removing please do!
 Oh and something that could be of intrest to someone, there is a set of yellow sport springs inside the car with red 'GM' logo on each, im happy with my suspension but if anyone is intrested, i'd be happy to recover n pay then send em on for the same as they charge me + postage - though im not sure if they are infact for an omega - they dont look like they ever got fitted before whatever car they were for met its maker  ;)
Re: Been down my scrappy
« Reply #1 on: 03 July 2007, 16:25:14 »
the smashed windscreen glass should be fine to sit on, move on. Its saftey glass, down my scrappy i have sat on seats with broken windscreen glass on, its not a problem.
The rear doors will not add any real strength to the car, try to open (carefully!) if it opens easy, then you should be fine. Its its stuck fast then you will have to get a drill!
You could try drilling the boot lock, other than that. No other way in, unless the key is still in the car. Which sometimes it is in scrappys! Check the glovebox  :y
luv_my_mv6
« Reply #2 on: 03 July 2007, 16:29:00 »
Hmm will get myself back down there tomorrow complete with cordless drill and breaker bar  :D cheers tunnie
« Reply #3 on: 03 July 2007, 16:38:59 »
Take care!! don't want you getting hurt or cut...
I have just found from personal experiance the windscreen glass to be ok (i was waring Jeans, t-shirt + a boiler suit) so quite a lot of padding!
You could always smash the window of the rear window and lean in, pull down the rear seats and see whats in there. Might be worth taking a pile of old rags or something to chuck in, so when you climb in, you have some padding  :y
I love scrappys, big kids playground!  :D
Craig_R
  • Watford
« Reply #4 on: 03 July 2007, 16:43:22 »
Which Scrap Yard is near NorthWood ? Is it NorthWood near Watford ? the only Scrapper I know of is in Bushey and i dont think they like me much for some reason.
I need a part for my 2.0L Can I ask where this scrapper is so i can get the part i need as the few in bushey always say Sorry I cant help you when i ask if there are any omegas in.
Thanks
Craig
Mod's
[To be Fitted]Reverse Sensors
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #5 on: 03 July 2007, 16:56:57 »
Just one piece of advice from someone who has been in the glass trade for 20+ years. If you are going to go scrambling about in broken toughened or laminated glass wear some gloves. You will not get cut but there are thousands of glass splinters that will probably get stuck into your skin. They are unlikely to do any damage but they sting like hell and take days to grow out. Then, every time you put pressure on that spot the splinter gets pushed back in.
Ouch :'(
[size=24]        [/size][/b]
luv_my_mv6
« Reply #6 on: 03 July 2007, 23:21:15 »
Thanks
Craig
I got to a scrappy in West Drayton, just the other side of Uxbridge, always loads of cars in there, only problem is the forklift truck, they dont look where they are going, so watch out for it if you go!!!
luv_my_mv6
« Reply #7 on: 03 July 2007, 23:26:49 »
Yeah I'd have to agree with you there tunnie, i'm in heaven when im in scrappys, I usually go in for a straightforward part that I need, and end up coming out with loads  ;D if I had a garden, i'd have my own scrappy  :D
Martin_1962
« Reply #8 on: 04 July 2007, 09:48:29 »
I have used them a lot - huge one near Cheltenham - Harry Buckland
I had a lot there for my Sunbeam, rear wash wipe, door pockets, better interior trim, radiators, cylinder head, even stripped a Chrysler 180 of its rear calipers.
Got an engine for when my mum had an old Avenger estate, swapping engines over then was so easy compared to today.
Big Rod
  • Fife, Scotland
« Reply #9 on: 04 July 2007, 10:18:13 »
Scrappies are brill'!!
I do try to have my own one from time to time, (Trying for it now as it happens!!), but SWMBO usually nips it in the bud!!
Yeah, I  ususally end up walking out with much more than I went in for too!! (And not even necessarily for the same car either!!)
Very theraputic pastime!!
If I have to explain you won't understand!
« Reply #10 on: 04 July 2007, 14:38:52 »
i like having a good nose in the cars, often they are still full of personal history, who owns them and their address  :o :o
Our scrappy just seamed to have loads of old Jaguar XJS's in, had 2 of the 6.0 V12's and a 3.6.... quite interesting having a nose at the old Jags  :)
« Last Edit: 04 July 2007, 14:39:36 by tunnie »
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #11 on: 04 July 2007, 15:13:15 »
my local one is one crappy scrappy....just one omega - a facelift 2.2 thats fire damaged  >:(
« Reply #12 on: 04 July 2007, 16:57:33 »
If its still got the window switches on drivers door, I suspect tunnie will be your best mate ;)
