Author Topic: Oil extractor  (Read 3798 times)
Nickbat
Oil extractor
« on: 23 October 2010, 12:05:52 »
My local Vx dealer has run out of sump plug O rings, so my thoughts of doing an oil change this weekend have taken a knock. :(
However, I recall reading a thread about oil extractors on here (which I can't find!) and was wondering whether anyone can remember the thread OR can give me an opinion on these things. It would save me having to source sump plug O rings and, I understand would make oil changes easier (though I'd still have to crawl under the car to get at that wonderfully-sited filter!  ;)).
Re: Oil extractor
« Reply #1 on: 23 October 2010, 12:18:37 »
i would not bother with them, just wait until you can get an O ring for the sump bolt. I've not replaced the o-ring on mine for couple of years, is yours leaking?
Re: Oil extractor
« Reply #2 on: 23 October 2010, 12:19:40 »
I remember that as well but can't find the thread up to the moment - here is something  that may help;
http://www.honestjohn.co.uk/forum/post/index.htm?t=8893
    • E250 Est / Elroq
Re: Oil extractor
« Reply #3 on: 23 October 2010, 12:36:59 »
you only need to change copper washers every time.
the later torx plugs with rubber o-ring last much better
i keep some in stock and only change it if it looks tired / leaky  :y
Re: Oil extractor
« Reply #4 on: 23 October 2010, 13:30:09 »
My local Vx dealer has run out of sump plug O rings,  .....
Unless the O ring is obviously damaged, split, lumps missing etc you'll be OK to re-use the old one  :y  :y  :y The O ring isn't subject to much that would damage it, it's only squashed by a very small amount to make the seal when it's fitted corrected.
Re: Oil extractor
« Reply #5 on: 23 October 2010, 13:31:25 »
You could of course re-anneal it & use it again.
Nickbat
Re: Oil extractor
« Reply #6 on: 23 October 2010, 15:48:33 »
No, it's not leaking, Tunnie. Mine's the rubber version, so maybe I can get away with reusing it as you suggest.  :y
Nickbat
Re: Oil extractor
« Reply #7 on: 23 October 2010, 15:51:51 »
Thanks, Zulu. Some interesting comments there! :y
Re: Oil extractor
« Reply #8 on: 23 October 2010, 16:05:00 »
I replace the rubber 'O' ring every third oil change, and never have any problems ;) ;)
V6 CDX-er
  • Sheffield
Re: Oil extractor
« Reply #9 on: 23 October 2010, 16:20:29 »
Personally, and this is a matter of personal opinion based upon no fact whatsoever, I'd rather change the sump plug washer regardless. Could you not order one from another VX dealer and get them to post it? Failing that, I need to buy a load of parts next week, so I could order one from my local dealers if you want and post it you, (just send us one back next time you get one).
As for the oil extractors, I've used one once and found it to be a pretty pointless and frustrating exercise.
Re: Oil extractor
« Reply #10 on: 23 October 2010, 16:53:57 »
that depends if you have a sump drain plug, Smarts don't  :-?  :y
Re: Oil extractor
« Reply #11 on: 23 October 2010, 17:29:00 »
Easily, just watch when you release the plug, the ring sometimes sticks to the sump  :y
I really should get a new o-ring for mine, its done countless changes (every 3-4k) over 51k  :o  ;D
Re: Oil extractor
« Reply #12 on: 23 October 2010, 17:29:44 »
Thats not very 'Smart' is it?  ::)  :D
Nickbat
Re: Oil extractor
« Reply #13 on: 23 October 2010, 18:19:30 »
Thanks for the offer. I'll try and get one this week from another dealer, or maybe use the old one for now...it was only replaced 6 months ago.  :y
Re: Oil extractor
« Reply #14 on: 23 October 2010, 18:25:37 »
.... or maybe use the old one for now...it was only replaced 6 months ago.  :y
It'll be as good as new then, just re-use it, you'll have no problems.  :y
