Author Topic: CID's  (Read 2676 times)
joshwyatt
  • Oxford
CID's
« on: 24 October 2010, 22:06:23 »
If you're after a CID the best way is to buy a whole car I think, as it almost works out cheaper in the end. Take the CID, put a GID in it and sell it on for not much less than you bought it, if any less at all.
I was lucky and bought a damaged Omega with a CID, but there are currently two Omega's on ebay that are pretty cheap currently with CID's.
I'm not the seller of these vehicle, nor do I know the vendor;
http://cgi.ebay.co.uk/2000-VAUXHALL-OMEGA-ELITE-3-0-V6-AUTO-94K-MILES-SAT-NAV-/360313000091?pt=Automobiles_UK&hash=item53e454109b
http://cgi.ebay.co.uk/Vauxhall-Omega-2-6-CD-Saloon-manual-Leather-Satnav-/130447190910?pt=Automobiles_UK&hash=item1e5f422b7e
Re: CID's
« Reply #1 on: 24 October 2010, 22:09:55 »
Knowing my luck I'd end up not being able to shift the car on for some reason.. I have zero luck when it comes to buying & selling cars ;D
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: CID's
« Reply #2 on: 24 October 2010, 22:18:18 »
will a cid work with any stereo then? i thought you had to have one of the 2013/2015 NCDC units?
« Last Edit: 24 October 2010, 22:18:33 by ilovemyelite »
PM with your requests.
joshwyatt
  • Oxford
Re: CID's
« Reply #3 on: 24 October 2010, 22:21:48 »
The CID only works with the 2013 or 2015 as you say  :y
Re: CID's
« Reply #4 on: 24 October 2010, 22:41:51 »
You would have to remove the head unit as well, as the CID is paired to it
hotel21
  • The Kingdom of Fife
Re: CID's
« Reply #5 on: 24 October 2010, 23:14:08 »
Both the head unit and the display can be set to factory mode with Tech2 (depairing).  Display then replaced with, say, a GID instead of the CID and set back up.
The original headunit can easily stay in place.
Re: CID's
« Reply #6 on: 24 October 2010, 23:16:24 »
but swapping both bits would be easier for mortals without a Tech II  ;) ;)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: CID's
« Reply #7 on: 25 October 2010, 10:01:20 »
I have a spare CID - well spare in the sense I have all the bits - just need the TFT screen to replace the faultyunit -  I think the proper replacment is no longer available. Anybody got an alternative screen to the Toshiba?
Re: CID's
« Reply #8 on: 25 October 2010, 10:02:16 »
And don't use that piece of shite "My Naff Code Reader" to do this task - I have an NCDC2015 here that an OOF member buggered up pairing up with "My Naff Code Reader".
I was able to recover the display and the CD Changer, but the main board is as much use as a used johnny smeared in dogshite.
Still, I'm not complaining, his loss, my gain ;)
Re: CID's
« Reply #9 on: 25 October 2010, 14:46:23 »
I was able to recover the display and the CD Changer, but the main board is as much use as a used johnny smeared in dogshite.Still, I'm not complaining, his loss, my gain ;)
Whoever said the English Language wasn't expressive, obviously isn't a member of the OOF!  ;D ;D ;D ;D ;D ;)
Re: CID's
« Reply #10 on: 26 October 2010, 00:00:45 »
I'm sure H is slapping his legs as we speak.  ;D
