Author Topic: advice needed  (Read 2445 times)
razzo
  • Crapital
    • 97 3.0 Elite
advice needed
« on: 04 July 2007, 18:39:20 »
If you turn the ignition key on so the dash lights up but engine is not running, should the EML light go out after a few secs. If it does not is there a fault stored, the light goes out when engine is started
     any ideas  :(
mick-1975
  • nottingham
Re: advice needed
« Reply #1 on: 04 July 2007, 18:42:41 »
 hi  i have 2.0l 1999 estate and my eml light is on to but once started goes
 straight off
   mick :)
Admin
Re: advice needed
« Reply #2 on: 04 July 2007, 18:44:30 »
It should be on, the crank sensor will not be receving a correct signal (as crank is not rotating).  :)
« Last Edit: 04 July 2007, 18:50:33 by admin »
The Administrator.
razzo
  • Crapital
    • 97 3.0 Elite
Re: advice needed
« Reply #3 on: 04 July 2007, 19:10:30 »
Thanks for that guys :y
miggy
Re: advice needed
« Reply #4 on: 04 July 2007, 19:14:39 »
Great on here init. Better than the Haynes manual, i wish they did an Haynes for the facelift.
 :y :y :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: advice needed
« Reply #5 on: 04 July 2007, 20:56:45 »
 :y :y :y
They do .......it's called "General Help"  :y
DaveL
  • Nr. Cupar, Kingdom of Fife
Re: advice needed
« Reply #6 on: 04 July 2007, 21:13:43 »
 :y :y :y
 ;D ;D ;D :y
