Timing tools
Started by venom, 24 October 2010, 18:38:29
venom
I'm looking at getting this set, http://www.ldemporium.co.uk/engine-timing-tool-kit-for-v6-gmsaab-p-1626.html
but it says "1996-2003 3.0L used in Saab 9-5" so would that be OK for a 1997 2.5 ?
Ken
Welung666
Yes, it'll work on all the V6's :y
henryd
QuoteI'm looking at getting this set, http://www.ldemporium.co.uk/engine-timing-tool-kit-for-v6-gmsaab-p-1626.html
Have a look on eBay, I picked up a new unused Sykes kit for £35
other rides
Was going to say that price is a bit steep, but then it has the 30mill spanner and torx crank socket which not all kits do, and it is new...
...if you could source that kit on eBay second hand....?
But yes, will do all gm v6's.
Quote....
but then it has the 30mill spanner and .....
you don't get your 30mm spanner from work then?  ::) ::)
Quote....
Yep, but had to give it back  >:( although I can borrow it back I suppose  :-X
Quote....
you should've said, you could've have had the one I had in the boot at Newent.  ;) ;)
Quotehttp://cgi.ebay.co.uk/Vauxhall-V6-Timing-Belt-Fitting-Tool-/330488042264?pt=UK_Hand_Tools_Equipment&hash=item4cf29f5318
minus 30mm spanner..
Could get away with no crank tool on a 3.2 or a 2.6 with fixed bottom pulley I suppose, but not on a 2.5 or 3.0.
venom
#10
This is how most of the Laser kit comes, brand new kits from tool shops come without the Crankshaft and Camshaft Locking Tools and are sold separately  :( , which is why I did think the Bergen kit seemed quite a good price
Ken
I wouldnt buy a laser kit even if it was complete tbh. They are not known for their accuracy in the cam timing dept.
Sykes pickavant seems to be the recommended brand for v6 locking/setting kits.  ;)
venom
If you look on the Sykes pickavant site the kit looks the same as the Laser set  :question
Ken
It may look the same but apparently some members have found them to be less than accurate when setting the cam timing. ;)
venom
Ken
