Author Topic: Slightly off topic...but still Vauxhall!  (Read 2125 times)
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« on: 04 July 2007, 13:49:34 »
Just read codes on my sister's Astra ('96 1.6 petrol) come up with code 0505 which according to booklet is Idle speed stepper motor/Idle air regulator,can this be cleaned or will it need replacing?...Many thanks...Wayne
Re: Slightly off topic...but still Vauxhall!
« Reply #1 on: 04 July 2007, 13:55:31 »
thats the icv...
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 04 July 2007, 13:56:30 »
Clean and lube as normal ;)
Cav9_4
« Reply #3 on: 04 July 2007, 13:59:44 »
Thanks TB/Dazzler....try and get it done now....inbetween showers...rain showers that is!
« Reply #4 on: 04 July 2007, 14:37:39 »
No...its not an idle valve.....I suspect its the C16NZ engine which is a single point injection setup (Multec?) with a throttle body, bloody huge injector and a small bypass channel for the idle function.
The stepper motor is mounted on the front of the throttle body and held by two torx screws, remove it and give it a dam good clean and a light lube (peel back the rubber boot).....if you re-connect it, every time the ignition is turned on and off it should operate (no need to start the car) as a little test.
Also give the throttle body a dam good clean and the orrafice into which the stepper motor fits.
Cav9_4
« Reply #5 on: 04 July 2007, 14:42:58 »
Hi Mark and thanks :y...your'e right it is the C16NZ  SPI engine in at the moment (raining AGAIN)...but hopefully try and get it done...Thanks again....Wayne
familyman
  • Sittingbourne, Kent
« Reply #6 on: 05 July 2007, 09:15:50 »
Just a note check around the throttle body for a label 'cause some have a coating so you mustn't use carb cleaner or other solvent on the TB just wipe with a rag the best you can :y  If its not to late now
You came in that, your braver than i thought
