Author Topic: Polly bushes experiences...  (Read 5859 times)
« on: 12 November 2010, 12:13:29 »
Anyone got them fitted? Front or back. If so what's your opinion of them. I guess what we all want to know is are they too harsh...?
Plus anything else you can tell us good or bad. Price,  supplier etc...    Ta.
Martin_1962
Re: Polly bushes experiences...
« Reply #1 on: 12 November 2010, 16:46:29 »
Doesn't seem any harsher - possily a little but nothing to worry about
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« Reply #2 on: 12 November 2010, 17:45:53 »
A little harsher maybe but not a great deal  :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
« Reply #3 on: 12 November 2010, 18:10:48 »
...oh, so not recomended then?  :-?
Martin_1962
« Reply #4 on: 12 November 2010, 19:15:03 »
Feels more planted and less loose at the front
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #5 on: 12 November 2010, 19:15:45 »
Done doughnut bushes & front wishbone bush on both our cars & i would recommend them to anyone. I made up front wishbone bush over 3 years ago on swmbo's car cos they were not availble then & i  pressed them into cheap wishbones £50 a pair jobbies, also it was only 1 of 2 cars that passed at the WIM meet & iirc 13 out of 15 failed that day & Tony couldn't set the geometry cos so many standard bushes were shot, never had an advisory or fail on them & saves me a fortune in tyres.
Just a thought maybe we could get some of those who poly the wishbones to another WIM meet & see what the success rate is second time around. If i got another Omega i wouldn't hesitate to do it all again, even mentioned it to my local MOT tester & he is thinking of offering poly bushes for wishbones to his customers as so many standard bushes fail after a while.
Chris, just do it you know you want to & if your diving is a bit on the enthusiastic side even better, just to add i was advised by the people who know not to poly the rear bush on the front wishbone as it would cause too much vibration through the steering but i am gonna make up a set & see what happens  :y
Kneepad
  • West Scotland
« Reply #6 on: 12 November 2010, 19:33:55 »
That should be interesting. As far as I know,  polybushes for the rear of the front wishbone do not yet exist.
« Reply #7 on: 12 November 2010, 19:40:11 »
Word on the other thread (from Powerflex, IIRC) was that with standard poly bushes they'd seen the bushes tend to tear themselves apart, but had now designed some kind of spherical poly-mounted bearing that could possibly be made to work in our application - they just hadn't made a bush set out of it yet..
Kneepad
  • West Scotland
« Reply #8 on: 12 November 2010, 20:07:53 »
That was my point.  ;)  IIRC They could possibly do this if there was enough interest. It will be interesting to see what comes of this.   :y
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #9 on: 12 November 2010, 20:28:51 »
last time i cut the rear bush out of a wishbone it looked solid rubber, nothing spherical or bearing wise so can't see why a poly bush the same dimensions would not work as a replacement but please feel free to prove me wrong
2woody
  • Northumberland
« Reply #10 on: 12 November 2010, 20:38:08 »
this is actually quite difficult.
on the front, the horizontal bush is easy to change, but wouldn't gain that much from being changed without the vertical bush, which because of its design can't be made in a "poly" material. Actually, a harder horizontal bush could shorten the life of the vertical bush, but that's no real problem.
The lower wishbone is designed to flex, with the rear of the wishbone moving across the car whilst pivoting around the front bush. This increases comfort ( the front wheel likes to have a low stiffness in the front-to-rear plane ). So, you can see that the front bush is already quite hard - it would be the rear one that you'd need to improve.
On the Lotus Carlton, the vertical bush was re-made in a harder rubber.
on the rear, there are two sets of bushes to consider.....
subframe bushes.
some gains to be made from changing to stiffer donuts I think, but at some cost to comfort. Probably worth noting that the Holden manages to dispense 400HP with no rear end bush problems.
wishone bushes.
Don't change the wishbone bushes for poly ones. simple. The geometry is such that the inner bush flexes a lot becuse the camber/track correction bar needs it to. Stiffer bushes will prevent the wishbone moving properly.
« Reply #11 on: 12 November 2010, 23:47:23 »
Those that have them swear by them, albeit with a little coaxing  ::) maybe just shy ?
But in fiddling around with wishbones in the past, they do flex it seams as said.   :-/
« Last Edit: 12 November 2010, 23:48:38 by chrisgixer »
« Reply #12 on: 14 November 2010, 12:04:11 »
subframe bushes.
wishone bushes.
Generally, I would hope, that the Polly bush design would be fractionally firmer than stock, but most importantly not degrade at all over time/miles covered....?
And have often wondered if a n other subframe design complete from another GM car would serve better...?
    • 530D M Sport, 330i Coupe
« Reply #13 on: 14 November 2010, 12:07:44 »
subframe bushes.
wishone bushes.
Not that many RWD GM's available now to choose from  :'(
« Reply #14 on: 14 November 2010, 12:16:42 »
subframe bushes.
wishone bushes.
Plus, to add, the front  wishbone bush design strikes me as flawed(admittedly as a layman with no education on the matter, and with so many failures, no prizes for saying  ::). ) the main block of the bush internals sits vertical  :-? Where as the stress from the road wheel is delivered to it on a horizontal plain, so it's twisted continually by suspension movement, and forced in and outboard by breaking forces... No wonder the centre block splits away from the bush outer!
 But what to do about it...? If Polly are a solid lump then I guess that would be concerning and over  harsh, I'm guessing ...? There must be some give, which I'm told there is.  :-/
« Last Edit: 14 November 2010, 12:19:08 by chrisgixer »
