Fuel transfer pump
Started by Auto Addict, 19 November 2010, 12:25:43
Auto Addict
Got me thinking, after my autobox oil change last weekend.
Anyone know of a reasonably priced, efficient fuel transfer pump, suitable for the job?
I like red cars
mantahatch
I made my own fuel transfer pump using an old red top petrol pump and nice long leads and long tubes. Whether it would do ATF I don't know.
Debs.
Didn`t Machine Mart used to sell a giant "oil change" syringe affair?.....I wonder if; connected with a length of rubber hose terminated with a suitably bent, 8mm. dia. copper dip-pipe, it would work.
At last fluid-change, whilst the pans were off; I simply drilled through and TIG welded a nut (fine metric thread) to the centre of both pans and use a bolt and soft-copper washer as a drain plug......`well worth the effort and sooooooo-much less hassle! :y
Auto Addict
#3
QuoteDidn`t Machine Mart used to sell a giant "oil change" syringe affair?.....I wonder if; connected with a length of rubber hose terminated with a suitably bent, 8mm. dia. copper dip-pipe, it would work.
We used a Machine Mart syringe, it was hard work.
I like red cars
Welung666
Get a cheap "killaspray" type device (Aldi / Lidl have them very cheap every so often).
Remove the spray lance and replace with a bit of copper microbore tube bent into a hook at the end.
Fill with ATF, pump up, hook the tube over the filler/level plug and leave it to fill. :y
