What to replace with wishbones?
Started by Arrolman, 23 November 2010, 23:20:39
Arrolman
Hi,
Am going to get my new suspension fitted next week and get the wishbones done at the same time, what else do I need to replace at the same time? Had seen a link to control arms? Idler has already been replaced
Cheers,
Iain
Looking to win the lottery..........
Kneepad
Drop links, track rods, ARB bushes and donut bushes should all be checked and replaced if necessary.  :y
Only really leaves the steering side of the job at the front, so track rod ends, centre tie rod assembly but only if there is play they are expensive, and steering idler you've done.
Could do wheel barings if there is any play.
If your re using your old top shock mount assembly make sure there's no play at the top of the shock before you remove it, and grease the baring while it's apart, they don't seem to fail so re using should be fine.
Anti roll bar has no affect on set up as such, but always worth checking anyway.
Rear donut bushes as said, check the rear bush blocks at rear of dif aren't de laminated, and that there is no play in the trailing arm bushes, which I guess is easiest to do with the springs out.
If you want to do the rear anti roll bar bushes these are best done while the springs are out and the dif dropped as the guide. Also check rear wheel barings and pray they aren't failed. Nightmare job to replace.
Hth
Arrolman
Hi guys,
Thanks for the advice, rear bushes are getting replaced at same time as I do the LSD diff oil. Any links to decent track rod ends?
Cheers,
Iain
Delphi from a factors seem ok. Try suttons/by parts buy.
Do not be tempted with Delphi wishbones btw.
QuoteDo not be tempted with Delphi wishbones btw
What he^ just said. :y
I wouldn't buy them again if you gave me the cash. >:(
Would settle for lemforder or vx ones if you're offering though. :y
