Author Topic: omega with bent valves, some progress.  (Read 1628 times)
Ken T
  • Stockport
« on: 06 December 2010, 22:24:24 »
last time I had sought a quick way forward by getting a head from a scrapyard. However on reflection it looks worse than mine, and might need a lot of effort to put it right.  So after some searching I found a guy in Bradford who recons engines and heads, and who seemed reasonably priced. So I  dropped both heads off with him. He is to fit 4 new valves and guides if required to the first head, and I took along the second one for him to put into his degreasing/cleaning tank to see what it looks with all the carbon off. I pick them up tomorrow so hopefully will be all set to refit when I get some time.
I haven't yet checked all the valves for leaks, I will follow the advice given by Matchless re using a torch to see if they all seat properly, then its clean up the block and refit time.
I know its taking me a while, but I have another 3 cars to look after !. My daughter's husband's Megane has a knackered water pump, which is a right pain to replace, so it might be going to the scrapyard. We just got another car for my wife, an 06 Corsa Design with 25K on the clock, for £2K, except .... I'l tell all some time !. So I am driving my Wife's ex corsa, 03 with the intention of fixing a few faults and giving it to my daughter. All just small niggly things but they take a while. Also the heater doesn't work. Well it works but the heat output is very low. I ordered a new heater matrix from those quality sellers from Ebay, but the pipe holes were at different angles ( supposed to be perpendicular  :P ) so I couldn't get it back into its air chamber. So take it out, put the old one back in , refill with antifreeze and shiver on the way to work, again  :P
Plus work are giving me lots of extra things to do, I have to time division multiplex everything, which means things seem to move very slowly. Never mind with a bit of luck I'll get a head refitted this weekend and enjoy some quality driving.  :y :y :y
Thanks again Mark for the offer,
Ken
« Last Edit: 06 December 2010, 22:25:58 by Ken_T »
Debs.
Re: omega with bent valves, some progress.
« Reply #1 on: 06 December 2010, 22:58:59 »
Hope you`re taking pictures, Ken.....perhaps this rebuild should be a 'how-to' guide for the maintenance section! ;)
Ken T
  • Stockport
« Reply #2 on: 07 December 2010, 00:29:59 »
Hi Debs,
I think it would be more a a "How Not To"  ;D ;D ;D
Ken
P.S. that hill of yours in the photos, have you thought of running ski-ing trips there ?, using the landrover to pull them back up the hill ?. Add a few chalets and you could make a few bob. Just an idea.
Ken
« Reply #3 on: 07 December 2010, 21:03:57 »
Could of had it fixed by me by now Ken  ;D
As for the fixed head, fit some plugs, turn it upside and fill the combustion chmber with brake fluid, parrafin or similar.....check the ports after a few hours for leaks. This will tell you if the valves are seating correctly.
