Author Topic: :S 2000 OMEGA HAYNES MANUAL  (Read 2338 times)
Jaymd
« on: 10 December 2010, 19:58:29 »
i thought about investing in the trusted haynes manual for my 2000 omega i checked the website amazon and halford an i couldnt find one anywhere any one had the same problem as me im assuming that they didnt make one. how weird.
vauxfan2k
  • Western Isles
Re: :S 2000 OMEGA HAYNES MANUAL
« Reply #1 on: 10 December 2010, 20:03:39 »
haynes only made manuals for 94-99 models, tho the mechanicals are basiacally the same, only the interior trim and some extras only found on f/l models not in manual.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #2 on: 10 December 2010, 20:05:06 »
You can normally get cheap second hand ones on ebay
TC and BnQ Trade holder.
Jaymd
« Reply #3 on: 10 December 2010, 20:07:35 »
ahhh i see i did toy with the idea of buying the older one but the fact it didnt have 2.2 engines on the front put me off a bit
geoffr70
  • Sunderland
  • Boobies
« Reply #4 on: 10 December 2010, 20:14:05 »
AFAIK the 2.2 is the 2.0 with a longer stroke - someone correct me otherwise.
vauxfan2k
  • Western Isles
« Reply #5 on: 10 December 2010, 20:16:20 »
aye something like that, but for all the work you wil need to do to the engine etc, it will suffice, for everything else theres us lot  ;D
Jaymd
« Reply #6 on: 10 December 2010, 20:20:45 »
okie doke ill add one to my xmas list and you guys are diamonds dunno wat i would have done without the help and advice cheers :D
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #7 on: 10 December 2010, 23:02:20 »
anything you need to know  you would be better asking on here :y
« Reply #8 on: 11 December 2010, 10:50:08 »
Pfl Haynes is def worth having, 2.2 is drive by wire, so different throttle body etc.
Where's Tunnie? He has two thirds of the experience on these  ;)
« Reply #9 on: 11 December 2010, 12:35:33 »
fine engine the 2.2, unlike the V6  :P :P
Make sure throttle body is clean, follow the guide  :y
The little breather pipe from the throttle body to the cam cover can easily block, its cheaper to buy a new one than clean it, they are about 70p from a dealer!
Fresh oil really, really makes a noticeable difference on them I change mine every 3k, good coolant maintenance as well as if you leave it the HG can go
« Last Edit: 11 December 2010, 12:35:55 by tunnie »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #10 on: 11 December 2010, 14:22:58 »
I have a copy which I no longer need
You may have it FOC
PM me (I'm in Hampshire)
