Author Topic: did autovaux supply the wrong timing belt ?  (Read 2371 times)
Ken T
  • Stockport
« on: 12 December 2010, 22:46:43 »
I am busy refitting the rebuilt head, and come to the timing belt and stuff. The new belt they supplied is 2.7cm longer than the old one. The box says its for a Frontera 2.2i long and sintra 2.2i 16V, no mention of Omega.
Have they supplied the wrong part ?
Ken
davethediver
  • Blackburn, Lancs.
Re: did autovaux supply the wrong timing belt ?
« Reply #1 on: 12 December 2010, 22:49:43 »
Ken
That doesn't sound to good Ken :-/ :-/
P.A. Caron de Beaumarchais
Ken T
  • Stockport
« Reply #2 on: 12 December 2010, 22:55:18 »
I am right ****** ***, I have spent quite a few hours over the weekend fitting everything, and was hoping to get her finished tonight, so could finally check things tomorrow and hopefully get back on the road, in comfort, however the time taken to sort it out and wait for them to send the correct one, or they may expect me to go there to change it.  :P :P :P
Why can't they sort them selves out and sell the right part. :'(
Ken
andyc
  • Norfolk
« Reply #3 on: 12 December 2010, 23:05:10 »
EPC list the same belt for the Omega, Frontera and Sintra.
As its from Autovax i take it its a Non Vauxhall Boxed item, it could be a case the the kit  has been mis-packed by the manufracture
Andy
Thetford. Norfolk
    • 530D M Sport, 330i Coupe
« Reply #4 on: 12 December 2010, 23:07:45 »
A while ago they were selling Aux belts for V6's that were too short.... surely there has to be some middle ground!
Ken T
  • Stockport
« Reply #5 on: 12 December 2010, 23:26:04 »
Andy
Could be, it says on the box Conitech CT 924, 171 Z.
If it fits all these models, I will be surprised. The tensioner will have to move over about 1.3cm to take up the slack, and I doubt it can go that far.
Ken
« Reply #6 on: 12 December 2010, 23:47:12 »
Contitech kit for 2.2 16V - Y 22 XE, Z 22 XE is CT924K1 - should contain . . . . .
1 off CT924       Timing Belt
1 off V55342     Tensioner Pulley, timing belt
2 off V55314     Deflection/Guide Pulley, timing belt
HTH
Ken T
  • Stockport
« Reply #7 on: 12 December 2010, 23:54:32 »
Thanks for that, will be interesting to see if the tensioner get tight enough.
Here's hoping :y
Ken
mrjimbo
  • Oxfordshire
« Reply #8 on: 13 December 2010, 02:36:58 »
HTH
Does the belt that they supplied match what is supposed to be in the kit ? there should be a number on it somewhere.
