Author Topic: Handbrake adjustment on s reg fiat seicento?  (Read 2901 times)
Omega_Dan
« on: 29 January 2011, 19:27:25 »
Is their an adjuster anywhere to slacken off or tighten up the handbrake?
Dan ;)
Re: Handbrake adjustment on s reg fiat seicento?
« Reply #1 on: 29 January 2011, 19:45:30 »
Dan ;)
Have you had a look Dan?  ::) ::) ::)
I'd have thought there had to be some kind of adjustment!  :-/
Omega_Dan
« Reply #2 on: 29 January 2011, 19:47:38 »
Im going too tomorrow. Just trying to get a heads up ;D
« Reply #3 on: 29 January 2011, 19:49:46 »
Check the usual places... Around the base of the lever (normally under a flap op removable panel of some kind) and under the car
« Reply #4 on: 29 January 2011, 19:51:07 »
I'm no expert, but I believe they can have problems with their electric assisted power steering, apparently it's possible to get assistance on one lock but not the other for which you need A N other column!  :-? :-?
Omega_Dan
« Reply #5 on: 29 January 2011, 20:00:38 »
Luckily its an early seicento sporting with no power steering :y
« Reply #6 on: 29 January 2011, 20:07:37 »
Fancy buying Mrs 282 a car without power steering :o. You have it, why shouldn't she?  ::)  ::)  ::)  ;D
Omega_Dan
« Reply #7 on: 29 January 2011, 21:39:29 »
Mate its proper light! i was well suprised! she had a little spin in it and no complaints! all is good ;D
And she defo isnt driving the mig :o
« Last Edit: 29 January 2011, 21:40:02 by Omega_Dan »
« Reply #8 on: 29 January 2011, 22:08:02 »
 ;D ;D ;D
Omega_Dan
« Reply #9 on: 30 January 2011, 17:40:20 »
Right had a go today. Under the cat where the handbrake is there are 2 adjusters (one for each side). Using a 10mm socket i adjusted it a fairway and it did losen it slightly but not enough still.
Anything else it may be?
« Reply #10 on: 30 January 2011, 17:55:09 »
Sounds like you need to get the wheels and drums off then ;)
Omega_Dan
« Reply #11 on: 30 January 2011, 18:16:02 »
It will adjust a bit more so ill see if that works first :y
