Pages: 1 2 [3]  All   Go Down
Author Topic: Smartcar NOT so Smart!!  (Read 6360 times)
Re: Smartcar NOT so Smart!!
« Reply #30 on: 03 February 2011, 11:27:40 »
I can see your point on that, although if thats the case it would be as easy to just drop another engine in, at £500 for a decent second hand unit. :-/
« Reply #31 on: 03 February 2011, 11:55:34 »
They appear surprisingly durable in kit cars, contrary to what you might expect. I tour with quite a few guys who run bike engines doing pretty high road mileages and abuse them on track (you wouldn't put up with BEC "ergonomics" for road use alone!).
They have swapped the odd tired engine between them but IME they will last much longer than 10k miles. Most failures are due to the oil system not being properly engineered causing oil surge or scavenge pump drive failure rather than wear.
When you consider that you can drop a standard bike engine in from a scrapper (and bikers are always putting them through hedges) whereas at the same level of performance with a car engine you are probably doing at least a bit of tuning work, and hence investing time and money in the engine, I'm not sure, from a durability point of view, that there's much in it for a small, light car.
You'd have to ask how durable a Smart engine is against a normal car engine too, of course!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #32 on: 03 February 2011, 12:05:43 »
then the engine in its compartment:
Looks to see if he can spot the "Briggs and Stratton"
Of Milwaukee USA, Mr Wood? ;D
Quite like the Lombardini jobs meself! :y
« Reply #33 on: 03 February 2011, 12:05:56 »
Ime the amount of use/abuse a japanese bike engine will take is astonishing.
They are brilliantly engineered. :y
« Last Edit: 03 February 2011, 12:06:24 by albitz »
« Reply #34 on: 03 February 2011, 12:12:38 »
Trouble is, your going a stage further again from a Kitcar as its heavier still and more likely to hit a lot of stop start driving.
« Reply #35 on: 03 February 2011, 12:13:58 »
Special Daz versions  ;D
« Reply #36 on: 03 February 2011, 13:12:55 »
Not much a daily driver with the bike engine fitted though.....and with full rebuilds every 10K miles to!
I don't deny it would be hugely impractical and not an every day car at all, but I bet it would be a blast down the country lanes - although they do have an absurdly high CoG (at least looking at them) .. perhaps a bike engined Smart Roadster would be more fun.
« Reply #37 on: 03 February 2011, 13:14:09 »
TBH, if you want something like that then a Smart in any form is the wrong starting point.
bluey
  • West Mids
« Reply #38 on: 03 February 2011, 15:24:14 »
You would have to pay me some serious dosh before I got behind the wheel of that bucketfull of sickness. Jesus, that is one horribly vinyl'd up concept by some friend of Dorothy agency exec rocking on Special K at the time.  And they got paid for that.
I was looking at these Smart things last year for some stupid 'I could save money' reason.  After seeing so many up for grabs with failed head gaskets and ovalled bottom ends I dropped the idea quicker than Katie Price's knickers.
There is one micro car I like the look of, although it's not in production which is a shame.  The T25.
Behind the wheel it doesn't have that nancy boy look about it either:
« Last Edit: 03 February 2011, 15:27:17 by bluey »
« Reply #39 on: 03 February 2011, 15:56:24 »
Its no concept, they are some of the sales fleet cars  ;D
« Reply #40 on: 03 February 2011, 19:28:59 »
Mine took a fair bit :-X :-X ::) ::)
Pages: 1 2 [3]  All   Go Up
