ADMINS
Started by miggy, 09 July 2007, 18:05:06
miggy
I dont know if you know but when you click on the MEMBERS or SEARCH tab at the top of the page, a page comes up for omega and rolex watches.
Miggy
Markie
mine is okay now, but i suspect not for others - as no one is posting..... :-/
miggy
Quotemine is okay now, but i suspect not for others - as no one is posting..... :-/
I am trying to answer various topics, but when Iclick the reply it comes up with a watch page, i have managed to reply on this one after 5 attempts.
Markie
seemed to be an issue earlier - i also could not get on to www.omegaowners.com - was directed to a watch search site....
glad youve replied it was starting to get a bit "28 days later  :o"
miggy
its now throwing me off saying i must register before i can answer, this was my 8th attempt to reply.
We are having a few problems with the DNS entries at the moment, you can try using the following IP address instead of typing the web address in as a short term fix:
217.155.56.220
miggy
QuoteWe are having a few problems with the DNS entries at the moment, you can try using the following IP address instead of typing the web address in as a short term fix:
217.155.56.220
Seems to be fine now.
Quoteits now throwing me off saying i must register before i can answer, this was my 8th attempt to reply.
Logging on using the IP address in the URL means the cookie used to recognise your logged-in "for good" status is not picked up and you'll be a guest until you log in again. Took me a minute or two to realise what was going on.
miggy
Cheers Kevin, seems ok now.
pete :y
Yes, I should have said that in the email that went out....
amigov6
:(Gutted! i thought you were knocking out Arthur Daley/Delboy timepieces!!! :D
Has the ISP that holds the domain completely cocked up then? The DNS wouldn't just change the A records to a random advertising site for no reason!!
QuoteHas the ISP that holds the domain completely cocked up then? The DNS wouldn't just change the A records to a random advertising site for no reason!!
Cannot entirely blame Hosting-Unlimited this time, only LB66 ;D.  In LB's defence, they never sent him any warnings about what would happen.
In a couple of months we will take measures to reduce the chances of this reoccurring.
Is this a roundabout way of Saying the Domain has expired?  :-X
I think we've said that in a number of threads....
