Author Topic: I hate garages  (Read 2986 times)
charlie
  • sunderland
I hate garages
« on: 08 April 2011, 11:30:02 »
AS above just been getting my camber,castor,toe,set up and he bloke said "an omega carnt alter/change the front camber on them" results on the new set up to follow :'( :'(
    • E250 Est / Elroq
Re: I hate garages
« Reply #1 on: 08 April 2011, 11:37:16 »
what absolute rubbish.....go somewhere better next time :y
Re: I hate garages
« Reply #2 on: 08 April 2011, 11:47:44 »
Frightening that this guy is working on people's cars yet clearly doesn't know his @rse from his elbow. >:(
charlie
  • sunderland
Re: I hate garages
« Reply #3 on: 08 April 2011, 11:52:58 »
Yip,im going to print off how to change the camber and take it back, as on the print out the n/s/f camber is out of tolerence.I know it should be -1 10 ish but its -0 17'. :'(
charlie
  • sunderland
Re: I hate garages
« Reply #4 on: 08 April 2011, 11:59:53 »
                PRESENT FRONT DATA
            left                     right
toe     0.0mm                 0.5mm
total toe 0.5mm
camber - 0^17'              -0^56'
cross camber    0^39'
                    PRESENT REAR DATA
TOE             1.0MM            0.8MM
TOTAL TOE     1.8MM
camber   -2^09'                  -3^05'
cross camber     0^56'
thrust angle      -0^01'         off
^ donotes degrees as i carnt find it on the keyboard
Re: I hate garages
« Reply #5 on: 08 April 2011, 12:08:15 »
Yep. That needs adjusting. Make sure he readjusts the toe as well, as adjusting the camber will mess up the toe setting. :y
Would have been quicker for him to do the job properly the first time round. ::)
89mustang
Re: I hate garages
« Reply #6 on: 08 April 2011, 22:14:10 »
You should also get castor measured, it is adjustable unofficially, by moving the subframe. It needs to be even rather than correct. This will be beneficial to the driving experience when everything else is corrected. May I suggest someone more willing to do a proper job?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: I hate garages
« Reply #7 on: 09 April 2011, 00:16:17 »
The thing is would you trust a chimp who has fed you a line like that?
TuBy's new whipping boy.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: I hate garages
« Reply #8 on: 09 April 2011, 00:28:54 »
where did you take it charlie?
TC and BnQ Trade holder.
Re: I hate garages
« Reply #9 on: 09 April 2011, 22:48:40 »
Somewhere to avoid..... :y
Re: I hate garages
« Reply #10 on: 09 April 2011, 23:15:44 »
Appalling, don't leave it too long, tyre wear at another camber setting will affect handling. Not enough camber will likely give a flighty unconnected feel in conjunction with the wear from the previous setting.
I'd be looking for a cash refund and take else wear tbh. Not good at all. Name and shame.....
the alarming man
  • medway kent
    • disco V8
Re: I hate garages
« Reply #11 on: 09 April 2011, 23:17:58 »
have you a wheels in motion franchisee by you?? :y
Bigfoot
Re: I hate garages
« Reply #12 on: 10 April 2011, 22:01:30 »
Not even all the wim franchisees know the camber is ajustable on omegas, till you tell them , experience.
davethediver
  • Blackburn, Lancs.
Re: I hate garages
« Reply #13 on: 10 April 2011, 22:09:55 »
If they don't i think Tony would like to know so he can get rid or re-educate >:(
P.A. Caron de Beaumarchais
Bigfoot
Re: I hate garages
« Reply #14 on: 10 April 2011, 22:19:57 »
yes reported and sorted at time, last year, but you loose confidence , so will stick with making the trek down to  chesham  :)
