Author Topic: Project Engine Rebuild.  (Read 9639 times)
Re: Project Engine Rebuild.
« Reply #15 on: 22 March 2011, 10:53:10 »
Nice pictures :)
MDTM, could you do me a strange favour? Measure (roughly) how long the 'fingers' on your engine stand are (or can spread at max spread)?
I bought a Sealey ES550 only to find that it's fingers don't go nearly wide enough to reach the bellhousing bolt holes on the 390 (it has a huge bellhousing, admittedly) and apparently the next size up Sealey stand is even smaller :-/ I'm struggling to find one that'll reach.
I will try
I have an ES350 (Clarke one but its exactly the same and from the same factory) and I had the opposite problem as I have no bell housing adaptor plate fitted at the moment so its a bit narrow!
Cheers :) The length of a 'finger' and the width between the widest point of the mounting slots on the back plate would be perfect actually - then I can just compare that to mine :)
Failing that I suppose I'll just have to get some longer fingers made up and hope it doesn't all collapse under the weight ;D (Mind, that tractor engine must weigh at least what the 390 does? About 350Kg?)
I couldn't quite believe the size of the bellhousing on the 390 though - biggest flywheel I've ever seen!
« Reply #16 on: 22 March 2011, 11:14:53 »
Its about 300Kg without the flywheel and adaptor plate (which wont be fitted until its suspended from a crane shortly before mating to the gearbox)
« Reply #17 on: 22 March 2011, 11:39:15 »
Cool - at least I know (if necessary) the 'littler' engine stand will hold the weight, then :)
« Reply #18 on: 22 March 2011, 21:31:09 »
Ok, the distance between the hole centres on the fingers is 115mm and max distance the slots will set to is 185mm
So max width would be 415mm.
A few more pics here:
The machined main bearing cap with the thrust bearing placed in position:
And fitted:
I also fitted the crank sprocket (having found the missing Woodruff key) and the crank seal (which was a right pain to do)
« Reply #19 on: 22 March 2011, 21:37:06 »
Sadly, with a rather poor 2G mobile internet connection, I can't see the pics, but look forward to read this thread at the weekend, when I rejoin civilisation :y
« Reply #20 on: 22 March 2011, 21:38:46 »
nice work that - it's maybe only 18months since I rebuilt a 4-cylinder version of same engine, again for a tractor.
Next job is a set of 6 cylinder DMU engines and some liner seals on a big Sulzer
« Reply #21 on: 22 March 2011, 21:45:28 »
O oh, tractor party...  :D;)
« Reply #22 on: 22 March 2011, 21:45:57 »
Thanks for that :) Same width as mine, sadly :( Well, guess I just have to manufacture something!
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #23 on: 22 March 2011, 22:03:17 »
AEC per chance ::)
« Reply #24 on: 22 March 2011, 22:09:57 »
interesting thread with piccies :y :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #25 on: 24 March 2011, 16:03:54 »
I see you're 'ploughing' on with this job then Mark ;)
I like red cars
« Reply #26 on: 25 March 2011, 08:33:20 »
I hope to ream my little end tonight ready for fitting the pistons  ::)
« Reply #27 on: 25 March 2011, 08:35:28 »
Would it be excessive to ask for some pics of this. ;D ;D :y
« Reply #28 on: 25 March 2011, 08:37:20 »
Of course, what ever floats your boat.  ;D
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #29 on: 25 March 2011, 09:28:33 »
Watch out for excessive crankshaft end float on those.
'Twas not unknown for the thrusts to drop out from the centre main bearing.
Pages: 1 [2] 3 4  All   Go Up
