Author Topic: Project Engine Rebuild.  (Read 9588 times)
Re: Project Engine Rebuild.
« Reply #45 on: 04 April 2011, 08:50:59 »
looks like brand new engine :y
« Reply #46 on: 04 April 2011, 09:51:47 »
Looks really impressive Mr DTM :y.  I suspect Mrs DTM will be pleased when its finished and out of her garage :P
But the engine is all wrong. It needs to be a single cylinder diesel made by Lister for fitting in a little yellow run-around ;D
« Reply #47 on: 04 April 2011, 21:28:20 »
Trial fit of the cylinder head (as its new).
Lots of cleaning tonight, cylinder heads studs, water pump, fan, class 47 Run-Oil-Pressure switch etc etc
« Reply #48 on: 10 April 2011, 21:43:16 »
Ok, head fitted:
With the rocker cover off (i just place it on to protect the internals)
And a bit of a pain this one......trying to get loads of paint on this bit as the raised section is the 'A' material!
« Reply #49 on: 10 April 2011, 22:14:26 »
very visible that there is considerable effort spent.. good one Mark :y :y
Matchless
  • Nottingham
    • A white van
« Reply #50 on: 11 April 2011, 10:14:55 »
Good progress, other non-stated reasons for ownership:
1. Mark wakes early due to offspring and doesnt see why other residents of the close should remain asleep.
2. He wants to out-perform caravan owners in the queue creating stakes.
On the big-end caps there was a domed bit....is that solid metal for balancing or is it hollow for a sludge trap?
There is something wrong under the rocker cover, you can clearly see the rocker arms. Have you forgotten to install the sound-deadening glutinous black gooey stuff?
Otherwise known as :
[size=20]The Black Death[/size]
    • E250 Est / Elroq
« Reply #51 on: 11 April 2011, 10:17:41 »
Looks like its getting there  :y
« Reply #52 on: 18 April 2011, 20:51:02 »
Some more progress.
Its slowly turning blue
Injector pump fitted, timed up and the feed pipes fitted.
Pages: 1 2 3 [4]  All   Go Up
