Author Topic: Off to WIM on Friday...  (Read 5021 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« on: 12 April 2011, 13:42:36 »
...for some new boots and a full geometry setup on the car.
It's not seen WIM to date, as I was waiting for the existing budget tyres to wear down.  As it happens they have done so and guess what, it's the front inside shoulders that have worn down first.
So, time to get out the Plusgas and start spraying away  ;D.
I shall take a chance and hope that the rear track rod ends can be freed up on the day and that new wishbones won't be needed  ::).
But if they are then I shall just have to book in for a return visit  ;).
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
PMitchell
  • Oxford, Oxfordshire
Re: Off to WIM on Friday...
« Reply #1 on: 12 April 2011, 15:03:34 »
For what they cost at www.vauxhallworldparts.com I'd get a set in.  I just had the same, needed two front tyres so went for full alignment and geometry, and the blasted offside tie rod end (inner and outer) completely seized.  New tie ros assy complete was something stupid like 28 quid delivered, so I got it sent and had it fitted, then went back and had the alignment done again.  But all the faffing cost me more than 28 quid, so next time I might just change the arm anyway, even if it's not needed.
Cheers
Paul
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #2 on: 12 April 2011, 19:19:43 »
think this inside front wheel wear problem must be a miggy problem when I took Miggy down for her geometry check about a couple of yrs ago could'nt believe it both front tyres had  steel backing exposed at the extreme front inner corners had them replaced and the geometry done and drove a different miggy back to Leeds a real treat and she's still drives the same :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 12 April 2011, 20:57:03 »
I had mine in last week for a full set up, gambled on the wishbones being ok and got my fingers burnt, would have been far cheaper to have done them first but ended up getting them done there before the set up was completed as they were well knackered!
Mr Hagon
  • South West London
« Reply #4 on: 12 April 2011, 22:42:27 »
Are you saying that WIM keep a stock of wishbones purely for the reason that so many Omegas come in with knackered wishbones that it's worth their while doing so?
« Reply #5 on: 12 April 2011, 22:58:22 »
It's a long time ago .. but just after they opened WIM had a "clubday" at which they offered to do a free setup on a forum members car .. to be chosen at random on the day. If memory serves the first half dozen or so were rejected as unsuitable due to knackered wishbones  !!!!! So it seems to be a fairly common fault ..  :)
Mr Hagon
  • South West London
« Reply #6 on: 12 April 2011, 23:51:13 »
Oh yes, been there before with my previous Omega a couple of years ago.
Went for new tyres and came away with a need for new wishbones and also had the rear track rod ends replaced as WIM started to swap them out and recon them as it's easier than trying to free them off when they're seized solid.
So I expect to find all of this out on Friday; it's just that I need to pass the MOT first.  Should I need new wishbones etc. then I will get everything together and make a return visit at my convenience.
Martin_1962
« Reply #7 on: 14 April 2011, 11:04:21 »
When I last visited Tony was very pleased mine had poly bushes
Mr Hagon
  • South West London
« Reply #8 on: 14 April 2011, 22:46:42 »
Not sure about this, but I'm sure the subject will come up; will just have to do some more reading as to the pros and cons of them.
wheels-inmotion
« Reply #9 on: 15 April 2011, 10:18:57 »
Sadly i won't be there today....... My wife has been diagnosed with lung cancer so we are in a whole world of hurt at the moment.
« Reply #10 on: 15 April 2011, 10:41:30 »
I'm really sorry to hear this, Tony. :(
I'm sure all at OOF will join me in wishing her all the best.
« Reply #11 on: 15 April 2011, 10:46:51 »
As Kevin says ... I'm sure all OOF will wish her well.
Might not help at all, but, the prognosis now-a-days is extremely good, it will be tough .. but the success rate is very high...
All the best to you both
Nige
« Reply #12 on: 15 April 2011, 10:49:55 »
I am so sorry to hear of this Tony.
My thoughts are certainly with you and your family at this time
« Reply #13 on: 15 April 2011, 10:59:29 »
So sorry to hear such sad news Tony... Kind of puts my back pain into perspective :-[ :-[ :-[
But, as said, treatment has come on leaps and bounds and I wish you and your family all the best with it :y :y :y
    • E250 Est / Elroq
« Reply #14 on: 15 April 2011, 11:07:54 »
Hope everything works out ok Tony, just ready the story on your forum, and it sounds like you are getting looked after as well as possible :y
