I've just bought...
Started by JamesV6CDX, 10 July 2007, 18:50:49
... a Valve spring compressor, some fine and course grinding paste, and a grinding stick.
I'm going to have some fun with this head tonight!!!
Paint stripper, engine de-greaser and traffic film remover........got that to?
You dont do any re-build work on  head unless its realy clean.
Also, you need a tool to remove the stem seals.......should have mentioned that to.
QuotePaint stripper, engine de-greaser and traffic film remover........got that to?
Haynes book of lies says use a pair of long nosed pliers.. what else do you recommend?
I may well still call on you, if I get stuck ;D
Well put it like this......I dont own a pair of long nose pliers long enough to do the job and I have a reasonable range of long nose pliers.
This is what you need....because they are a long way down the machinings....!
https://sslrelay.com/buypartsby.co.uk/sealey-tools/sealey-display.php?recordID=1057
omega18
Sorry to Hijack this thread (Hope you don't mind  :-[ ) but are the steam oil seal pliers best to use when installing new seals??
Many thanks Karl
I use a 10mm deep socket on an extension bar to fit the seals....they fit a treat in the end and just push on.
omega18
Are the stem seals the same on the x20xev engine?
Cheers Karl
Yep....same head design and seals.......the valves on the 1.8 (big block), 2.0, 2.2 (Omega/Sintra/Frontera varient), 2.5, 2.6, 3.0 (with the exception of the exhaust valves which are sodium filled), 3.2 (as per 3.0) are all the same to.
Martin_1962
James could have used the valves out of the 2.5 heads then!!!!
Er, no....the car he has is the Z18XE1 which is the small block power plant (from memory)
QuoteEr, no....the car he has is the Z18XE1 which is the small block power plant (from memory)
Yep, that's right.
I've got 3 valves out.. including the broken one -
Interestingly, the broken one is a tad bent... but the guide and seat seem / feel ok... I've tried inserting a different valve into the guide, and it feels the same as the others..
