Pages: [1] 2 3  All   Go Down
Author Topic: Well that's breaked it  (Read 6267 times)
« on: 02 July 2011, 17:14:37 »
Took TBE for a drive to see if it inspired enough confidence to go to lakes.
It failed.
rather thing.
Re: Well that's breaked it
« Reply #1 on: 02 July 2011, 17:20:02 »
So what have you done to it now... Poor thing ::) ::) ::)
    • E250 Est / Elroq
« Reply #2 on: 02 July 2011, 17:25:43 »
TB The Car Destroyer  ;D
« Reply #3 on: 02 July 2011, 18:09:46 »
Misfires again?
« Reply #4 on: 02 July 2011, 22:02:44 »
Misfires again?
Like a bitch. So bad its knocking my fillings out
« Reply #5 on: 02 July 2011, 23:26:39 »
Misfires again?
So, new plugs, swapped coil PAC, no oil in wells ...
... And it still misfires.  :-?
Wiring to coil pac?  :-/.      (and sucking eggs :( )
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #6 on: 02 July 2011, 23:34:35 »
All the time, at idle, or only under WOT?
Does seem odd considering the recent checks.
Budget tyres, false economy.
« Reply #7 on: 02 July 2011, 23:42:31 »
It was under wot at the essex meet. Which is where the problem first arose I believe.
Seems to be getting progressively intermittently worse. No matter what's done to ignition system. 246 bank was the problem last I heard...?
« Reply #8 on: 03 July 2011, 00:11:30 »
Glad I wasn't driving :-X :-X ::) ::)
Actually... Doesn't matter.......... It's not my car :P :P :D :D
« Reply #9 on: 03 July 2011, 01:00:17 »
Yeah. Mines fine.  :)
« Reply #10 on: 03 July 2011, 08:30:16 »
Actually, this started once it was lpg'd didn't it?
Wonder if the injector wiring is iffy? Only reason I drove it was to test the kit, and it played up then and got worse since.
Or is it my memory misfiring as well?  :-/
« Reply #11 on: 03 July 2011, 08:38:34 »
Yeah, did start after the LPG went on. Shouldn't think it's the wiring... It took him long enough! ::) ;D But not rerally seen anything that points towards the LPG. Really needs to pull the fuse on the lpg or disconnect the injectors while it's got this miss to rule it out though :-? :-?
It's such a shame though because that kit runs perfectly on mine (and yours) so we know we've finally found the combination that works ::) Although I'm seriously considering trying a timing processor to see if there is any further improvements to be made ::)
« Reply #12 on: 03 July 2011, 09:04:33 »
Unless there's a very slightly trapped pipe less severe than I had. Although i'm sure he's narrowed it down to gas only or petrol or whatever.
« Reply #13 on: 03 July 2011, 09:06:15 »
Can that home made bit of loom be unplugged for a while?
« Reply #14 on: 03 July 2011, 09:32:01 »
Yep, and he can then run on Petrol for a while to see if there's any change.
Is the miss moving about or in 1 cylinder/bank? I wonder if the vapour hose is kinking when it gets warm and restricting flow? :-/ :-/
Still... Not a lot of point in us guessing randomly ::) ::) Reckon there must be a curry in my near future ::) ;D
Pages: [1] 2 3  All   Go Up
