Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: work for the last week (heavy pics mobile warning)  (Read 18294 times)
Re: work for the last week (heavy pics mobile warning)
« Reply #90 on: 14 July 2011, 21:04:26 »
cambelt set
I prefer instead of gm kit.. have the necessary markings .. and following the guides from here (I have the cambelt dvd files)
it was a perfect fit at the first trial..tensions correct, positions correct.. :)
« Last Edit: 14 July 2011, 21:24:57 by cem_devecioglu »
« Reply #91 on: 14 July 2011, 21:06:22 »
I found the 3.0 inlet cams from the breakers (only one pair)  .. and guess what, they were fractured.. >:( >:( >:(
an idiot hammered them  >:(
so I give up :'(
anyway engine is ok now.. much better than before as heads are polished.. tomorrow will start the manual conversion..
« Last Edit: 14 July 2011, 21:07:55 by cem_devecioglu »
Omegatoy
  • UK
« Reply #92 on: 14 July 2011, 21:09:44 »
bad luck Cem
never mind it runs good now, it will seem faster with the manual box anyway!!! :y
« Reply #93 on: 14 July 2011, 21:13:10 »
bad luck Cem
I'm like a children now and cant wait ;D ;D
« Last Edit: 14 July 2011, 21:13:37 by cem_devecioglu »
« Reply #94 on: 14 July 2011, 21:18:45 »
now the debate started at home .. I want to put autobox at home and swmbo dont want it ;D ;D :-/
Omegatoy
  • UK
« Reply #95 on: 15 July 2011, 08:41:03 »
easy!!
the rules are,
inside the house is the womans domain,
the shed , garage ,workshop, patio, garden, male domain!!! :y
« Reply #96 on: 16 July 2011, 22:52:43 »
today visisted the breakers and bought a vectra b 2.5 flywheel
and skimmed (or machined) with this
« Reply #97 on: 18 July 2011, 22:42:29 »
yippeee..
first drive with manual..
slightly modded engine, less weight,short differential ratio..it goes like a stink .. and roads were empty :o :o :-X
now its another car..
will post some pictures after mid is re-programmed and some small details :) :y
ps: vectra v6 smf works without any problem as expected..
« Last Edit: 18 July 2011, 22:43:19 by cem_devecioglu »
Omegatoy
  • UK
« Reply #98 on: 19 July 2011, 07:36:10 »
yippeee..
thats brilliant news Cem!!! :y just had a thought,please tel me you remembered to put a spigot bearing in the end of the crank though?
otherwise the box wont last long!!
    • E250 Est / Elroq
« Reply #99 on: 19 July 2011, 07:40:40 »
Good work fella!
« Reply #100 on: 19 July 2011, 10:44:19 »
yippeee..
thanks Omegatoy  :y
we put the spigot bearing .. I will post the pictures tonight (I hope I can go back home before 12 pm )
 :) :) :y
« Reply #101 on: 19 July 2011, 10:46:01 »
Good work fella!
Thanks Jimbob :y
the only downside is I used some credit and need to pay back.. :(    where is the nearest bank to rob ;D
« Reply #102 on: 19 July 2011, 19:54:38 »
here are the pictures from auto to maual conversion..
I'll be glad if anyone on here uses the pictures to explain anything or for any circumstance.. I'm not that pro to explain necessary steps in detail..(although I witnessed all steps and done some myself (little ;D :-[)
« Last Edit: 19 July 2011, 20:02:38 by cem_devecioglu »
« Reply #103 on: 19 July 2011, 19:55:29 »
« Reply #104 on: 19 July 2011, 19:56:29 »
Pages: 1 2 3 4 5 6 [7] 8   Go Up
