Author Topic: F1,TG,TV and "Boring"  (Read 3051 times)
« on: 24 July 2011, 23:16:29 »
So, guess a few will have seen Top Gear and the piece on Big knob head in the Cosworth F1 car. Bless him. ;D
Specifically, the bit about braking, appreciating it and understanding the performance envelope involved. Difficult, as non of us have over .5 of a million to physically try it. I'll never get close to that sort of performance certainly. Too old a fat now never mind the money.
However track experience is....  "Enlightening" I suppose you could say, and that works both ways.
e.g. Kevin Schwantz ex 500GP world champion once said about braking markers that he doesn't use them, preferring the "see God and then brake" approach. But what happens when you push past that point...? If you have it right, you run on.
 But if your god gauge is a bit out, as it will be unless your winning trophies, you find you still had some way to go before the brakes where truely needed. So you push past seeing God... Then your in real trouble as your now lost. Re calibrating your God gauge as the circuit approaches and each corner now has a different depth. Your God gauge is still telling you to brake... Brake....BRAAAAKE. But you now know that's still too early for the machine your on, or in. Brain says wait, keep the throttle pinned, fear and fight of flight instinct says save your life and brake now. Your head even moves back in preparation for counteracting the impending full stop, but no, that's still too early. It's like your brain is stretching, stop, pin it, brake, no wait... Bit more, NOW BRAAAAAKEING. 'dangle berries', still to early. Next lap try again.... And so  and so on until you calibrate and get God dialed in, so to speak.
.... that's about as far as i got with track work and braking. Frankly funds age and fitness couldn't cut it, and working with the God gauge started to cause Nausea between long breaks between track days due to cash flow, and a bit of club racing on bikes, long break another track day etc means you have to re calibrate again as it's been forgotten. Brands is a nightmare as it undulates alot, blind corners and hidden turn in points etc. Nausea again, so much more going on than braking on a flatter circuit.
So that's road racing on bikes(for me). Road bikes! Quick but not as quick as F1 obviously, not even close.
 Amplify that by what? about 70% ? As Clarkson demonstrated, that's a hell of a lot of turmoil in the brain dealing with the god gauge... Christ all mighty. How do they do it...?
Dont ever tell me F1 is boring. Ever! >:(
I just spent a good portion of the German Gp shouting at the TV as usual. Zoom out! Pan back, where's the impression of speed? And as for that long head on shot down the straight purely because there's a bit of heat haze to look through. BOG OFF  >:( is that all the producer can do to present the pinnacle of motor sport...? An obstructed view of an F1 car getting gradually bigger in size. What utter utter 'dangle berries'!  >:(
« Last Edit: 24 July 2011, 23:21:18 by chrisgixer »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: F1,TG,TV and "Boring"
« Reply #1 on: 24 July 2011, 23:22:15 »
I enjoyed both F1 and top gear today,thought they were both very good. :y
other rides
« Reply #2 on: 24 July 2011, 23:39:11 »
Gilles Villenueve used to do the "god gauge" thing in reverse. He would leave the braking waaay too late, spin,and then work back in incrememnets from there.He said there wasnt enough time to do it the other way round, it took too long.
He also based overtaking on his "gap theory"- once youve started the overtake, you will somehow find a gap.He also knew that one day he wouldnt find a gap, and sadly he was right.But the alternative was to be "one of those other boring tossers" who thought about it and then bottled it because it was too late. ;)
« Reply #3 on: 25 July 2011, 08:29:56 »
My bro, the lucky little bugger, got an all expenses paid trip to Spain to drive an F1 car, from one of his suppliers.
They put him in a single seater initially to get him used to the format, teaching him what to do when/where/how, then plonked him in the back seat of the 2 seater F1 to scare him wittless, before plonking him in a McLaren F1 (as in FIA, not the F1 sports car) to do some laps.
Lucky little tinker  >:(
And gayboy, he is of a similar build to me, so I'm sure you could be shoehorned in ;)
« Reply #4 on: 25 July 2011, 08:30:51 »
Actually, I think they put him in several single seaters with better and better performance...  ...I'll have to check with him
« Reply #5 on: 25 July 2011, 09:59:33 »
I drove a formula Ford single seater at one of these red letter day things. It was set up not to kill anyone, foremost, with a 4k RPM rev limit IIRC. ;D
When they realised I was getting bored bouncing off the rev limiter they gave me a formula Renault which was a little less restricted, had sticky rubber and aerodynamics.
Well I did half a dozen laps building my speed up and then started getting cocky on the last couple of laps (as you do).
Went into a right-left-right complex a little quick and ended up on completely the wrong line for the middle bend. Went to tighten the line just a tad and the next thing I knew I was going backwards through kitty litter. :o
It felt to me that there was absolutely no warning whatsoever. However, on speaking to the instructor afterwards, he said they struggle to get the cars tuned to be docile enough for the unwashed to come and drive them, and reminded me that that car set up for race use would be at the bottom of the ladder that leads, eventually, to F1.
I guess that's why the only way in is to be racing karts from the age of about 12. ::)
« Last Edit: 25 July 2011, 09:59:47 by Kevin_Wood »
« Reply #6 on: 25 July 2011, 18:49:38 »
Indeed. It's the coverage that's frustrating. Love the few onboard shots.
Motogp on board cameras, ESP at Sachsenring , are awesome. gyro cams. Seems a simple thing as a viewer to allow for a horizontal horizon on a conventional camera, but when level somehow it's one less thing to sus out when looking riders eye at the oncoming track. How much power is being layer down at such an acute lean angle, and when the rider in view slides or goes for an overtake it's spell bounding on occasion. But even they don't show anywhere near enough onboard. In fact the commentators often instantly shut up so as not to talk over the engine note. The juggling of physics becomes more apparent.
Cars don't need a gyro cam obviously, bikes have that extra dimension. A bit more knife edge, and a finer tuned "God gauge" as they physically can't stop as quick as a car, and God is more likely to appear if the rider cocks it up.
Commitment in MotoGp is awesome. But so rarely comes across on TV. although to be fair, the slightest twitch in wheel alignment/grip level feels like death is moments away, but is rarely as dramatic to a TV audience.  :(
Motor sport on tv is a highly frustrating experience IMO.
« Reply #7 on: 25 July 2011, 18:51:40 »
So how do you judge when to brake?
« Reply #8 on: 25 July 2011, 18:52:23 »
... And conversely, when to finish braking...?
« Reply #9 on: 25 July 2011, 19:13:10 »
As you say, based on how much turtle touches cloth. The point of contact is time to brake. Hard. Very, very hard  ;D
For mere mortals like us, we lack the ability to perfectly judge it. Sometimes we are too cautious, sometimes we overcook it (sorry joshwyatt, your tank was heavier than it felt ::)).
Braking is probably my strong point, be it in cars, karts and 'Event' days. Probably my weakest area is judging weight (re)distribution, and using that to my advantage to get it round corners as quick as possible.
« Last Edit: 25 July 2011, 19:13:42 by TheBoy »
« Reply #10 on: 25 July 2011, 19:27:03 »
;D Depth perception....?  ;D
Some choose a marker and creep it further up towards the corner. Doesn't help with looking round the corner IMO.
« Reply #11 on: 25 July 2011, 19:29:52 »
Markers are only useful on a track if you follow the same perfect lines every single lap, and screw you over if offline due to overtake etc, before you even consider differing conditions. Obviously can't use markers on roads, as you don't do any corner often enough  :-/
« Reply #12 on: 25 July 2011, 19:46:41 »
Was thinking track work. Pros promote markers. Clearly useless on the road, and is a good reason not to ride or drive on the road at all to start with. Bad habits etc. Hence carting entry level is a good idea as Kev mentioned.
But even so, I doubt I'd get on with markers.
« Reply #13 on: 25 July 2011, 19:48:42 »
I suspect a pro doesn't look for the markers, just simple 'knows' where they are in relation to them.  Also, at 170mph, how useful is a 300/200 marker, it will just fly past ;D
« Reply #14 on: 25 July 2011, 20:01:25 »
And when to stop braking...?
 Specifically, choose you corner speed while braking, when reached fling the brake off, turn in, apply power
Or, brake later then trail brake and turn, gradually releasing brake pressure to match grip level as your desired corner speed as reached. There by matching maximum grip level up to the apex, and allowing later braking, but buggering tyres quicker....?
You, I know are the first one. Point and squirt merchant. (snigger)  ;)
« Last Edit: 25 July 2011, 20:02:49 by chrisgixer »
Page created in 0.027 seconds with 16 queries.
