Crankcase what if??
Started by Tony H, 14 July 2007, 21:46:00
Tony H
I was just thinking, what if you where to drill the crankcase and fit an earlier conventional breather system, what would be the pro's and con's? Would it conform with emmition regs? how would it effect the engine running? also would it make cleaning breathers and leaking cam covers a thng of the past? :-/
QuoteI was just thinking, what if you where to drill the crankcase and fit an earlier conventional breather system, what would be the pro's and con's? Would it conform with emmition regs? how would it effect the engine running? also would it make cleaning breathers and leaking cam covers a thng of the past? :-/
If you quickly chean the breather sthrough every 6 months, can't see a need to bother with anything else?
Tony H
I was thinking about how it would effect the running of the engine?plus as regards the breathers would it be a case of "fire and forget"
