Author Topic: MV6 springs and ride height  (Read 1840 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 13 August 2011, 12:56:38 »
I have just changed my front wishbones, springs and shocks (poly wishbone and rool bar bushes) and I used what I though were 2nd Hand mv6 springs.
I was under the impression that mv6 springs sat a little lower than stock so imagine my suprise when I notice that the front is a little higher than it was on elite springs.....
Now my shocks and springs were very tired and the wishbone were proper buggered and I have the lpg tank in the boot (which i beleive is either full or has a fair bit of lpg in it)
I have yet to take it for a spin which might settle things down a bit but I was wondering if this was normal?
P.S.  My arms are fooked now, I am not sure which is harder on the arms, swapping heads or changing entire front suspension on both sides  :-X
Re: MV6 springs and ride height
« Reply #1 on: 13 August 2011, 12:59:24 »
depends on the age....
Pre-facelift shocks different springs same..... facelift it was shocks & springs for MV6 spec
« Last Edit: 13 August 2011, 12:59:50 by tunnie »
Gaffers
« Reply #2 on: 13 August 2011, 13:07:02 »
Im using bilstein b4s for the shocks.  If needs be I'll get some new springs for the back as well but I was hoping not to have to
« Reply #3 on: 13 August 2011, 13:12:36 »
fancy changing my rear springs while your at it?  ::)
Gaffers
« Reply #4 on: 13 August 2011, 13:15:53 »
Whats it worth?  ::) ;D
« Reply #5 on: 13 August 2011, 13:19:08 »
Cheap Sky?  :D
Gaffers
« Reply #6 on: 13 August 2011, 13:23:56 »
Cheap Sky?  :D
PM inbound
Gaffers
« Reply #7 on: 13 August 2011, 17:20:32 »
Ok after driving it around for a bit she has settled down nicely  :y
    • E250 Est / Elroq
« Reply #8 on: 14 August 2011, 09:00:46 »
Im sure B4's have a special valve system that means they self adjust to natural spring height :-/
« Reply #9 on: 14 August 2011, 10:04:25 »
Lowered sports chassis is face lift only. So if you have pre face lift mv6 springs, which are not lsc, and your old springs where buggered and sagging badly it may well sit higher.
Exactly what springs do you have?
Gaffers
« Reply #10 on: 14 August 2011, 13:29:07 »
PFL mv6 springs
« Reply #11 on: 14 August 2011, 13:49:49 »
PFL mv6 springs
Fairly sure they are exactly the same as any other spec of that age....
Gaffers
« Reply #12 on: 14 August 2011, 13:57:55 »
PFL mv6 springs
Arse, break and bugger!
