Pages: 1 [2] 3 4 5 6 7 8 9   Go Down
Author Topic: Newent 2011 Jobs List.  (Read 21541 times)
Re: Newent 2011 Jobs List.
« Reply #15 on: 07 August 2011, 20:47:10 »
Ive a front crank seal.....but probably not the best place for it.
Best leave that till you do a cam belt & tensioners
« Reply #16 on: 07 August 2011, 21:12:22 »
Can't quote for some reason :-/
1.That reminds me Chris, I owe you a hack saw blade iirc.
2.Did my bushes at the Lakes. Not the most comfortable experience, but as long as not raining should be easy enough. :y
« Reply #17 on: 07 August 2011, 21:16:07 »
1.That reminds me Chris, I owe you a hack saw blade iirc. .....
I'll replace that for if you want. I don't think I've ever had to buy one  ::) What do you want? 18 24 or 32 tpi  ;) ;) ;) It can go on the shelf with the can of copper slip  ;)
« Reply #18 on: 07 August 2011, 21:43:31 »
Don't worry Al, give it to TB if you see him, I broke one of his the other day.  ;D
Although I'm sure he's not bothered.  :y
« Reply #19 on: 07 August 2011, 21:44:21 »
... Having said that it was buggered long before you had it.  :-[
« Reply #20 on: 07 August 2011, 22:23:04 »
 ;D Sure I won't have done it any favours though... ::)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #21 on: 08 August 2011, 09:52:26 »
Need to get rear donut bushes replaced. Is this a big job and can it be done at Newent? Wishbone bushes also need doing but I'll get those done at my garage as they have the equipment to do the wheel alignment/geometry that'll need doing afterwards.
    • E250 Est / Elroq
« Reply #22 on: 08 August 2011, 10:20:46 »
Thats some time off unfortunately
« Reply #23 on: 08 August 2011, 11:31:10 »
If you like using your cam lock kit you can do your oil seal when ever  ;) ;)You'll need your big f*uk off breaker bar to undo/tighten the crank shaft bolt.  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #24 on: 09 August 2011, 01:12:20 »
Rear donuts ...........
Mr Gixer's very kindly offered his services already!  :y :y :y :y :y
Taxi_Driver
« Reply #25 on: 09 August 2011, 18:36:18 »
Fortunately for me, I have a totally reliable Fiat, so it doesnt need fixing  ::) :P
« Reply #26 on: 11 August 2011, 19:19:57 »
Hmmm, I might have as well  :'(
« Reply #27 on: 11 August 2011, 19:22:07 »
Huh? Eh? What?  >:(
Bloody vandal  ;D
« Reply #28 on: 11 August 2011, 19:23:07 »
As to jobs on my cars, depends which one I bring ;D
Joking aside, nothing planned on mine for Newent, mostly because she will probably want it to go shopping!
« Reply #29 on: 11 August 2011, 19:39:13 »
Potentially a radiator swap :-/ :-/
Pages: 1 [2] 3 4 5 6 7 8 9   Go Up
