Author Topic: So what have you done to your car today?  (Read 8336369 times)
0 Members and 43 Guests are viewing this topic.
T.m.f
    • 4wd
« Reply #11400 on: 26 November 2015, 19:30:08 »
Took the ka in for mot yesterday
It failed which i expected being a ka.
Both front top mounts worn
Both wishbone bushes worn
1 rear axle bush worn
Rear handbrake ineffective
Rear brakes ineffective
1 advisory was a small corrosion area on chassis
So today changed both wishbones,and replaced both top mounts and bearings,all done in under 4 hrs.
Just waiting on brake parts to be delivered and a set of poly rear axle bushes.
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
« Reply #11401 on: 26 November 2015, 23:53:55 »
Been determined to get to the bottom of some LPG injector issues I've been having...
So I cobbled together a test bed to characterise them. ::)
« Last Edit: 26 November 2015, 23:57:07 by Kevin Wood »
« Reply #11402 on: 27 November 2015, 09:06:16 »
How many times has the filler flap surround been repaired?
And watch the rust, once they start they deteriorate very quickly.
T.m.f
    • 4wd
« Reply #11403 on: 27 November 2015, 09:24:54 »
Its had all the major rust repaired,new sills etc,petrol cap area not to bad,its a 1st car for partners daughter,so only need it to last several years.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11404 on: 27 November 2015, 09:26:24 »
No shit,had to weld up an 08 plate recently,awful things :-X
other rides
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #11405 on: 27 November 2015, 10:18:53 »
You'll be doing most of that again for the next MOT.
  • Auckland
    • Mazda MPV
« Reply #11406 on: 27 November 2015, 10:36:18 »
It looks like a bucket full of petrol with a fuel pump dropped into it and a stick of kryptonite lying on top  :D
« Reply #11407 on: 27 November 2015, 12:21:08 »
Grumpy I expect. b4ndit's is temperamental and mine's got the right hump!  ::)  ;D
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
« Reply #11408 on: 27 November 2015, 13:51:32 »
Clever bugger :y bit of a mad scientist going on there, where' ;Ds the Flux Capacitor??
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
EMD
  • Noofhampton
    • 95t
« Reply #11409 on: 27 November 2015, 16:27:15 »
Went to look at an 04 Zafira , sat in it got out and went home ... fek that  :( So basic and plasticy inside and the driving position is way to high on the lowest setting  :(
Omegatitis
« Reply #11410 on: 27 November 2015, 18:09:27 »
They are truly shite in every respect.
If you need that type of car, and want Vauxhall, at least look at the Zafira-B, as it seems improved/refined on the original.
« Reply #11411 on: 27 November 2015, 18:37:32 »
Warmer too ;)
« Reply #11412 on: 27 November 2015, 18:39:06 »
Warmer too ;)
Well, yes, but then if well try to save a bit of money by buying the crappiest Chinese junk from egay, you deserve to cook.
EMD
  • Noofhampton
    • 95t
« Reply #11413 on: 27 November 2015, 19:10:24 »
Aye , i can see that now . They look ok from the outside , this was 2.0dti in fast black but was very disappointed in every respect on the cabin trim and functions but i did get a good offer on mine , i was being cheeky as you do but he said ok  :o
£1100  :)
Bet ive spent that in the last 12 months on it  ::)
Omegatitis
« Reply #11414 on: 27 November 2015, 20:52:16 »
£1100  :)
For a Zafira-A?
Was it top of the range ("Elegance") and in A1 perfect condition?  If not, way, way, way overpriced.
And the 2.0DTi was a hopeless engine when GM started fitting it, and hasn't aged well.
Page created in 0.026 seconds with 20 queries.
