Author Topic: So what have you done to your car today?  (Read 8422459 times)
0 Members and 32 Guests are viewing this topic.
« Reply #19845 on: 26 February 2020, 23:31:07 »
Took it in for a service. Must be the only time in about 25 years I've taken a car in for anything other than an MOT but decided it was worth it because warranty.
They washed it and valeted it to boot, so it was almost worth the money for that alone. :y
neil74
  • newport
    • 2.6 elite estate.
« Reply #19846 on: 28 February 2020, 18:43:08 »
Ordered a drivers mirror to replace the one that was just kicked off by some little idiots as they strolled on past.
« Reply #19847 on: 29 February 2020, 07:42:19 »
Drove it to work and back. Washed it in a puddle on the way home :D
« Reply #19848 on: 29 February 2020, 11:58:05 »
Can't get more environmentally friendly than that. :y
Little Greta would be proud of you. :)
« Reply #19849 on: 29 February 2020, 12:20:05 »
Do it from above ;)
Doh! Talk about a brainfart moment.  Helps if you go done in front of the radiator ;D
Thanks for the tip Al :y
« Reply #19850 on: 29 February 2020, 12:28:06 »
Changed the temp sensor, and engine oil (but not filter :( - just too windy, was hard enough getting the oil from the sump into the container without it going everywhere).
Old oil was 7k old, and had gone quite dark, but sure I'll get away with not changing the filter this time.
Had a quick look at LPG, but the weather turned, so for now, just whacked the switch-over temp to 70C.  Suspect I might have to whack it up further, until I can find a solution (probably new injectors)
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #19851 on: 29 February 2020, 12:42:34 »
Washed all the bird shit off the Range Rover, think the birds were using it for target practice yesterday in the car park at work..😃
« Reply #19852 on: 29 February 2020, 14:40:52 »
Judging by the size of the dollops on my car, it would seem the pterodactyl  is not extinct in Lincolnshire. :-\
« Reply #19853 on: 29 February 2020, 14:45:53 »
Yep......for my £54.50 MOT the Tata was also given a wash and vac. Fancy pastries and coffee must have cost a few quid. Had to raise the headlights one full turn so they were not pointing at the ground though.
Did you use the Jaguar 3+  cheaper service option?
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #19854 on: 29 February 2020, 15:17:16 »
Got half way through soldering a new injector connector onto Airfix 1, but the cold wind, crap soldering iron, and the need for at least three hands forced me to call it a day.
Keith ABS
  • Maldon Essex
« Reply #19855 on: 29 February 2020, 15:20:27 »
 Tring to clean the Zaf in between very heavy hail showers. So heavy here it looked like it had snowed
    • E250 Est / Elroq
« Reply #19856 on: 29 February 2020, 17:03:04 »
Oil and Filter change on both the Golf and Merc
« Reply #19857 on: 29 February 2020, 18:17:38 »
Do it from above ;)
« Reply #19858 on: 01 March 2020, 11:49:42 »
What injectors do you have on yours?
    • 530D M Sport, 330i Coupe
« Reply #19859 on: 01 March 2020, 15:42:14 »
Did the oil and filter, cleaned the breathers and changed the fuel filter on the daily.
