Migv6 le Frog Fan
A combination of a bad back and a run of nights stopped play during cambelt change. Started cleaning and reassembling everything a couple of hours ago, but rain has stopped play again.
If I get an hour or two of dry weather tomorrow it should be up and running again - fingers crossed.
pscocoa
Waiting for following day delivery from interparts - I have a tracking no. but no idea who carrier is. Focus stripped out ready.
Finally got round to putting the engine cover back on the Shaguar :)
Topped up the fluids in the Omega, and topped up the electricity in the Battlebus.
Rangie
Filled the Subaru up with fuel & had a run into Stamford very pleasant.
BazaJT
Had the 960 in for M.o.T. on Friday which it failed on handbrake efficiency.Other than that it had a clean sweep not even an advisory.Going to try adjusting first[lever goes to 9 clicks at present,but if it needs new shoes they're only £14+shrapnel per set so not an expensive fix.Not at all bad for a 25yr old car I don't think.
Took the Pussy for a run, as its only done short trips for the last month of so.
Also took the Battlebus for a small 20m run, as god only knows when that did more than 50yrds ;D
Migv6 le Frog Fan
Finally got the Omega all back together after the cambelt change. Checked everything was plugged in and connected etc.turned the key and it fired up straight away.
And its running as lumpy as my old Mums porridge.  :'( :'( :'(
Fitted refurbished headlights. Hopefully these will adjust as required.
Quote from: TheBoy on 11 October 2020, 15:41:34
Isn't 20m LESS than 50yds :-\
Quote from: Migv6 le Frog Fan on 11 October 2020, 17:17:00
Any codes?
Migv6 le Frog Fan
Nope just tried that. Just lifted plenum back off t check O rings seated properly. All looks ok too. Visually checked everything plugged in, connected etc. and all looks ok.
I will have to strip it down again and recheck timing. I have a suspicion its not that though, it looked spot on before the cover went back on. When I was trying to time it up with the wrong backing plate the drivers side cams kept slipping on the belt and turned almost a quarter turn when they did. I suspect one or two valves may have slightly bent. I hope Im wrong. :( :'(
I suppose a compression test is the only way to find out. Will try and get a run out to buy one in the morning.
Back to work for 4 nights tomorrow night, so progress will be slow again. ::)
Quote from: VXL V6 on 11 October 2020, 17:26:43
Well pretty happy with the alignment without any adjustments as yet.
I marked the the adjuster threads with a pen so I could wind the new adjuster up to the markings. This seems to have worked well for the initial setup *
* No pedestrians or oncoming vehicles were dazzled in this experiment  ;D
Prepared and sprayed the Dexta's bottom, its now a shiny Empire Blue like the rest of it.
Just need some new wings and to check the half shaft seals now there is oil in the back axle.
Migv6 le Frog Fan
#21028
Quote from: Migv6 le Frog Fan on 11 October 2020, 18:26:44
Got a compression tester this morning. Just used it on 135 bank. Figures from front to rear were 150, 170, 180.  Is the 150 a very bad sign or just wear and tear after 188k miles ?  Could it indicate a bent valve for example or would that be likely to give a much lower figure  :-\
P.s. This was with all three plugs removed from that bank, which I hope is the correct procedure.
Quote from: Migv6 le Frog Fan on 12 October 2020, 12:52:50
You should do a compression test with the throttle open, and the engine unable to start. If you're going to do it with the plugs out, remove all of them.
For this sort of diagnosis, the procedure isn't important provided you do the same for each cylinder. I wouldn't base any complicated repair on doing the test once.
Those readings aren't close, but none of them suggest a bent valve.
