My tyres never get below 3mm, can't see why you'd let them get any lower.
Diesel till I die
Quote from: STEMO on 16 December 2020, 16:34:01
Is that why you're keeping your Astra? The tyres still have 4mm on them :D
Migv6 le Frog Fan
Plenty of tread in the middle, but they are worn on inside and outside edges. Not sure why as I try and keep them around 33 psi.  :-\
Quote from: Doctor Gollum on 16 December 2020, 16:37:50
Yes
Diesel till I die
Quote from: Migv6 le Frog Fan on 16 December 2020, 16:38:28
Answer=omega and it's overly complicated suspension system.
Diesel till I die
Quote from: Migv6 le Frog Fan on 16 December 2020, 16:30:08
Yes.  :P
It failed on the towbar plate in the boot not being bolted down. I knew about this but didnt realise it was an MOT failure. Was planning on bolting it back down sometime soon, but now plan on doing it tomorrow morning.  ::)
Got an advisory on the front tyres which was expected. Will changed them in the next few weeks.
At least it wasn't a surprise issue, tyre advisories aren't really a big deal if you generally keep an eye on them as a matter of course :y
Because the Omega is a heavy car and pressing on through the corners does tend to chew through the edges of the front tyres. The only real solution is to slow down before the corners/roundabouts  ;D
Quote from: STEMO on 16 December 2020, 16:39:36
Add in reasonably wide tyres, modern offset wheels and that 'overly complicated suspension' is actually about as simple an IFS can be has compromised geometry.
Migv6 le Frog Fan
I dont drive it particularly hard and its been set up to WIM settings. Tyres have done 8k miles. They are Acellera ph1.
i THINK i will go for something different next time. They are pretty shit in the wet anyway, once they have a bit of wear on them.
Quote from: Migv6 le Frog Fan on 16 December 2020, 19:00:17
8K ??
That's about 1/3 of what I expect!!
I got my rears at 47,000 miles, now on 74,000 and still plenty of tread. Obviously FWD, so the rear is only being dragged along.
Diesel till I die
B52
Migv6 le Frog Fan
Quote from: Nick W on 16 December 2020, 19:28:01
8K ??
I did wonder about a possible alignment issue (settings a little too extreme ?) but would that cause wear on both edges ? I doubt it personally.  :-\
Thinking about buying these as replacement. Not awash with dosh at the moment, and they arent a bad price for new tyres from a brand Ive actually heard of.
https://www.ebay.co.uk/itm/2x-Avon-ZV7-235-45-R17-97W-XL-Tyres-Pair-Premium-Quality-235-45-17/184536261789?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
You can get those Avon's from ASDA Tyres for £151.28 fitted Albs.  :y
https://www.asdatyres.co.uk/235-45-17
Raeturbo
To be fair that type of wear is normally due to driving Pretty hard without enough air in the tyres. I would and do, run a few pounds higher and it helps a lot👍
Laying a rubber road.
