Quote from: Migv6 le Frog Fan on 26 May 2021, 13:38:47
Quote from: TheBoy on 26 May 2021, 10:14:25
Quote from: Migv6 le Frog Fan on 25 May 2021, 23:43:52
Quote from: Doctor Gollum on 25 May 2021, 20:18:47
Quote from: TheBoy on 25 May 2021, 18:11:20
Looking forward to paying £1820.76 for a new indicator bulb.  Once I prove it is the bulb.
Is that pre or post discount :-\
You do realise that you can buy a working S Class for that?  ;D
Another £79.24 and he could have a Boxster.  ;D
My hair is falling out without having a it blown in the wind ;D
Mines long gone, so Im well past having to worry about it.  ;D
You do like to go round corners fast though, and its a superb car for that, for a reasonable price.  ;)
Take no notice, Albs, I'm sure you look very cool  8)
Diesel till I die
Migv6 le Frog Fan
I stopped thinking about how I look about 20 years ago. Not much choice tbh.  ;D
Only Boxster I've driven was a 2004 vintage.  It didn't excite me like I expected it to, and ultimately left me disappointed.  So I kept my money.
It means that boat has sailed, as now need some level of practicality, being old and decrepid.
GastronomicKleptomaniac
Discovered a new repro rear valance for the Golf is not too expensive. Took great delight in cutting the old knackered one off. Should have joined the fire brigade...
YZ250
Quote from: YZ250 on 22 May 2021, 10:28:52
My daughter mentioned that the Corsa was acting strangely when braking. A quick test drive revealed a pulling to the right. Suspecting a lazy front left caliper I whipped the wheel off to check, and found the caliper piston seized.........
Had the Corsa to look at yesterday so I revisited the non-working front left caliper. Undone the flexi to rigid pipe connection and realised I'd mis-diagnosed the problem. No fluid coming from ABS pump to front left caliper. Careless, incomplete diagnoses from me the first time around.  :-[
A quick google and hundreds of posts came up, suggesting that it's a very common fault. So common that the part had to be redesigned to eliminate the flaw. Doesn't look that difficult a job to change, and if the part number matches or you change just the pump part, just a good bleed and away you go.
Viral_Jim
Hopefully a cheaper fix than a new/refurb caliper anyway.  :y
Quote from: YZ250 on 27 May 2021, 09:15:46
That's a sign of poor maintenance (lack of brake fluid changes), usually a tap of the ABS module frees the piston, then fresh fluid sorts it
Quote from: Marks DTM Calib on 27 May 2021, 10:21:01
<thinking cap on> I wonder whether a brake test on a loose surface / activation of the ABS would shake the ABS enough to free the stuck piston?  :-\ (on a private road at walking pace obviously)</thinking cap off>
YZ250
Fluid is very dark and never been changed. That was one of the jobs that I had the car over our house for.  :y  I'd just done the oil and coolant change when they mentioned the brakes.
Interesting about tapping the pump, I did give it a quick couple of taps with a nylon mallet but maybe the shock of a light hammer will do it. Thanks for the tip.  :y
As previously mentioned, the service history on this car is dire, so I have to grab it for inspection whenever I get a chance.  :)
Quote from: YZ250 on 27 May 2021, 12:07:51
No point in doing it until there is fresh fluid (all the circuits that are operational), you can get somebody to press the pedal, with the caliper bleed nipple open, whilst coaxing the module with a hammer close to the associated pipe.
YZ250
Quote from: Marks DTM Calib on 27 May 2021, 13:23:03
The plan was to use my Eezibleed on the working circuits to get fresh fluid in before changing the ABS pump. I'll still do that before tapping the pump though as at least if it does free it up it's got fresh fluid pushing past it. Thanks for the tip, fingers crossed.  :y
Found a breaker is an Indian indicator :)
But when I managed to contact them, they wanted £800, so I passed on it :(
Quote from: TheBoy on 27 May 2021, 17:00:17
In English, please  ;D
Diesel till I die
He's bought another Zafira on principle.  :D
Quote from: STEMO on 27 May 2021, 17:02:39
Just do the needful, and revert in any case.
is obviously means with. But Steve Jobs is a moron.
