Pages: 1 ... 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 ... 1938   Go Down
Author Topic: So what have you done to your car today?  (Read 6894389 times)
Field Marshal Dr. Opti and 64 Guests are viewing this topic.
« Reply #225 on: 21 May 2011, 22:36:02 »
Fuel lines tomorrow.  8-)
Guessing that means you're nearly there then... Who's got to do the electrickery for you this time... Kevin or TB? ::) ;D
Am I soldering next weekend then ::)
Well, hoping not to encroach in LD's jobs list too much. See how it goes. Is it a long job?
Is it just the 4 in the relay box, the 4/5 in the gas tight box, and the switch/buzzer ones?  2hrs at most if the relay box ones don't fight back too much...
Hopefully just the relay box stuff. Should be able to handle the other stuff.
It's cutting into the loom by the plug that gives me the willys.  :-/
Man Up and get on with it! ;D ;D ;D
« Reply #226 on: 21 May 2011, 22:40:11 »
Today Mathew I have been mostly ruining the paintwork on my bonnet while trying to repair stone chips after watching howto's on Youtube  ::) :( ;D
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #227 on: 22 May 2011, 16:32:32 »
Replaced the drivers door handle, after several weeks of having to get in via the passenger side. Jobs a goodun :y
Thanks to the forum for the door card removal guide.
Jon
Jon
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #228 on: 22 May 2011, 17:24:16 »
Haven't done anything to my own car, but I noticed that a mate in work's car was sounding rough when starting up and pulling away. In fact it sounded worse than a deisel. So at the end of work today we had a look under the bonnet (a 2006 Mini Cooper).
   Turns out he hasn't changed the oil since he's had it, at least 40,000 miles ago  ::)
Had a look at the dipstick and the treacle oil is only just registering on the bottom, waaaay below the minimum. The header tank is only half full of opaque, brown water which has splashed all over the engine at some point and stained it all, and he just hasn't got a clue about looking after his car at all
I just wonder how these people expect their cars to keep going, they pay through the nose for the best they can afford and think they look after themselves  :(
« Reply #229 on: 22 May 2011, 17:59:03 »
Typical BMW owner. What does he do, out of interest....?
jonnycool
« Reply #230 on: 22 May 2011, 18:02:10 »
Manager in a supermarket, like me
« Reply #231 on: 22 May 2011, 18:13:20 »
I knew it!  ;D.   ...and your not a BMW owner, clearly. So it's ok for you to be a manager. Just don't buy a Beemer, OK?  ;).  ;D
« Last Edit: 22 May 2011, 18:13:54 by chrisgixer »
« Reply #232 on: 22 May 2011, 19:02:45 »
Looked at my Omegas longingly as I clumbered into the back of a Hyundai i10 for a 120m round trip, only to be pleasantly surprised how little I ached at the end...
« Reply #233 on: 22 May 2011, 19:18:36 »
A future replacement for TBE?  ;D
All I did was get in, drive to Detling in Kent to be slightly underwhelmed by a field full of (very few) kit cars, wedged myself into a few Cobra replicas, got slightly insulted by one of the manufacturers and then drove home .. which would have been a nice cruise in the sun but was ruined by 7 chavs in a Zafira who decided to sit on my back bumper when they caught me in roadworks traffic, then undertake me, cut me up and do 2mph more than the middle lane for about 20 miles while washing their windscreen and looking back & laughing at me (as I was in the MR2 with the roof down, I presume they thought I was getting wet..).
Finally found a bit of clear road as myself & the Maserati behind me undertook them (which prompted them to try to ram me off the road) and I found the rev limiter in 3rd gear.
Bloody Vauxhall ow...er I mean..  ;D
« Reply #234 on: 22 May 2011, 21:02:44 »
Plenum/fanimold/LPG gubbins/ inlet plate/coolant bridge/ oil cooler plate/ oil cooler off. Cleaned up all the crap which had congealed around everything in the V of the engine. Put cooler and cooler plate back on - with a fresh smear of grey sealant around the plate.
Tomorrow - on 2 wheels to VX for dowty washers and banjo bolt washers. Then put everything else back together.
« Last Edit: 22 May 2011, 21:03:36 by albitz »
« Reply #235 on: 22 May 2011, 22:12:37 »
Today I have been mostly...
Getting grit in me eye while fitting fuel line clips... While I lay on me back, head under the car, next doors cat wondered over and curled up on my chest ;D ... WTF is that...  "ah!  Hello Bonnie". As she licked me nose.  ;D
2woody
  • Northumberland
« Reply #236 on: 23 May 2011, 08:53:35 »
intended to finish fitting the new exhaust to the Holden and to rebuild the gearbox and fit the aluminium flywheel and new clutch. Oh yes, and change the headers, too.
fell down on the knackered spigot bearing, so didn't get finished. Anyone got a spigot bearing for an LS1 Chevy engine ?
still, managed to get a caliper and the exhaust changed on the Disco.
« Reply #237 on: 23 May 2011, 09:11:51 »
Is this Holden work on the latest one?
Crazycarzowner
« Reply #238 on: 23 May 2011, 11:40:23 »
Well I've finally squeezed the Miggy into me garage (that was a work of art in itself). Now to start work on that major service - Oil, air, fuel filters, leaky oil cooler plate to sort out, new plugs, and new camcover seals too.Take off plenum & give breathers a bloomin good cleanin (well & truely gunked up). Then front wheels jacked up & off to check discs & pads and creaky rattling noise at front off-side. Repeat disc & pad check at rear & maybe adjust handbrake. I might be finished by teatime  ;D ;D ;D  ..................
..........next week!!! :D :D :D
2woody
  • Northumberland
« Reply #239 on: 23 May 2011, 15:57:01 »
yes - it's getting a trans rebuild & some other stuff. Nice big knobbly cam on the way, too
Pages: 1 ... 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 ... 1938   Go Up
Page created in 0.024 seconds with 20 queries.
