Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 ... 1940   Go Down
Author Topic: So what have you done to your car today?  (Read 8456081 times)
0 Members and 37 Guests are viewing this topic.
« Reply #240 on: 23 May 2011, 19:43:17 »
Today I have been mostly...
Getting grit in me eye while fitting fuel line clips... While I lay on me back, head under the car, next doors cat wondered over and curled up on my chest ;D ... WTF is that...  "ah!  Hello Bonnie". As she licked me nose.  ;D
I hope you drove through a farmyard first...  ...I had a sense of self satisfaction knowing you were getting covered in cowshit when you did mine ;D
    • 530D M Sport, 330i Coupe
« Reply #241 on: 23 May 2011, 21:39:45 »
Quick oil and filter change on my DTi, and a bit of grease slapped on the brake lines while the oil drained tonight.
Discovered slight play on the OSF track rod end so that's a job to do before the MOT at the end of June....  ::)
« Reply #242 on: 23 May 2011, 22:04:26 »
finished fitting this
Fitted a new compressor yesterday, what a pita job that is! Especially when you've a sore pinky!  ;D ;D ;D
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« Reply #243 on: 24 May 2011, 01:00:35 »
owwwwwww, that looks painful  :o
« Reply #244 on: 24 May 2011, 09:47:37 »
It was and still is  ::) although it is already starting to feel less tender to touch. I banged it on Sunday morning at work ie the day after it happened, I wanted to sit on the floor & cry!  :-? ;D ;D ;D
o-meg-a
  • south wales
« Reply #245 on: 24 May 2011, 17:25:00 »
Just finished doing rear subframe bushes and new centre and back box.
all done, back in the garage tomorrow morning for wishbones and lowering springs.
fun times
« Reply #246 on: 24 May 2011, 20:36:40 »
Towbar (and twin electrics) and a new battery fitted today thanks to johnnycboy and Albs :y :y :y
Crazycarzowner
« Reply #247 on: 24 May 2011, 21:18:02 »
Oil cooler removed Stripped & reassembled, one cam-cover done & 3 plugs changed. Other side to be done tomorrow. Got one thing to moan at...... that bl***y oil filter cannister!!!!!!! What an absolute Ba****d!!!!!!! Spent more time on that damn thing today than anythin else GRRRRRR!!!!!!
« Reply #248 on: 24 May 2011, 21:45:58 »
Today mostly back ache tbh, but in between twinges....
Filler on tow bar and air tight pipe work fitted. Just need some connectors and the back is done. Then it's cabin switch and poke the loom with a stick and we're there almost. :y
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #249 on: 24 May 2011, 22:37:53 »
Cleaned a LOT of sh!t off the windscreen and bonnet!
And chucked in air and pollen filters so I can feel I've made a start on the service.
Why are we so gullible as to buy pollen filters?  I take a walk outside so I can breathe fresh, unfiltered air.   :-?
I feel like a military academy. Bits of me keep passing out.
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #250 on: 25 May 2011, 08:08:30 »
You've obviously never suffered from hay fever mate
    • E250 Est / Elroq
« Reply #251 on: 25 May 2011, 08:15:14 »
and to protect the vent internals, nice to longer have a crinkly old leaf somewhere in the vents rustling in the breeze  :y
TheDaddy
  • Milton Keynes
« Reply #252 on: 25 May 2011, 09:44:34 »
Recently bought the Black Beastie from the Amigo and just starting to get used to working on the car and getting my hands dirty.
Removed and refitted the rear parcel shelf wiring in the blind.
Changed the cone filter back to the original air box.
Removed, cleaned and replaced wishy washy motor's. Now working well.
Next jobs will be to get some cats and a exhaust and replace the lovely fruity sounding stainless exhaust system on it :'(. Unfortunately the wife does not seem to share my view on how she sounds.
Looking forward to maintaining thi
« Reply #253 on: 25 May 2011, 10:55:06 »
Took the plenum back off only to find that my LPG problem isnt what I thought it was going to be. Im sat here stuck now. :'(
Shelby
  • Sleaford, Lincolnshire
« Reply #254 on: 25 May 2011, 15:40:34 »
Well, gave the old girl a good clean over yesterday and will be doing the same again today after two massive bird turds found their way onto it in the office car park!
Then tonight its having a look at the fuel pump cover plate etc. to see if there is any signs of leakage after I filled her up a few weeks back and ended up making a nice puddle Tesco forecourt!
Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 ... 1940   Go Up
