Author Topic: So what have you done to your car today?  (Read 7578376 times)
0 Members and 34 Guests are viewing this topic.
« Reply #23115 on: 10 December 2021, 18:20:32 »
I can assure you its replacement will not be a Mercedes Benz. And never will be until they discover how to design cars again, which isn't looking likely any time soon.
Mum and dads neighbour has just chopped his e class estate in for an A46AMG, its pretty lively (god knows how long such a highly tuned 4 pot will last! ) but, the front and rear is horrible, the interior really low rent and the audio system does not even have a touch screen and is a nightmare to use  :-\ :-\
Thankfully he still has the Aston  ;D
A really expensive all wheel drive clit rally car...
« Reply #23116 on: 10 December 2021, 19:05:29 »
I don't like touch screens. My COMAND is operated via a dial
countrywoman
  • worcestershire
    • skoda yeti
« Reply #23117 on: 10 December 2021, 21:11:38 »
Bloody heater fan stopped working on the Yeti, Goggled it and common fault if left standing and its been idle for 6weeks while I was in hospital and recovering. Bit of a fiddle getting it out but it just twists and drops out the underside of heater in passenger footwell. AS soon as it came out it worked , lubricated the bearings and tried to get it back in. Bugger the big thick wiring loom that runs across bulkhead wont let it go back in so glove box and foot vent pipe out and 2 screws in lower dash and then it just went in . Only prob was the foot vent pipe wont twist to go back on properly so it just butted up , will still work and I don't have the floor heat on as a rule. Took about an hour.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #23118 on: 11 December 2021, 12:10:09 »
Pierre has been playing silly buggers again this week. After fitting a new injector it ran nicely again - for a couple of weeks.
Thus week it seemed to have a big flat spot just where the turbo should kick in, then the turbo kicks in higher up the rev range than it normally would.
It has got steadily worse, and yesterday threw up fault code 2263 - turbo boost issue.
It could be the second hand turbo I fitted at the beginning of this year is on the way out, or it could be something associated such as a blockage / air leak / vacuum / sensor /  etc. etc.
Will start having a look at it later, but not really sure how to diagnose the problem.
No smoke or oil being chucked out the exhaust (yet), so Im slightly optimistic it isnt the turbo itself.
I havent (yet) had the ECU coded for the new injector, but I doubt thats connected to this issue.
I hear the Swan Vestas calling to me once again.  ::)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23119 on: 11 December 2021, 12:38:13 »
It's a well known issue TURBO boost fails clicky   :P
leaky intercooler hose/pipe or fitting or vac leak perhaps
you give that Cl-Eeyore so much LOVE  :-*
hope you get it sorted BEFORE the impending Ice-age  :)
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #23120 on: 11 December 2021, 13:52:23 »
If it’s a variable geometry turbo then it’s dirty/carbonised vanes I would suspect.
Laying a rubber road.
Migv6 le Frog Fan
« Reply #23121 on: 11 December 2021, 14:43:14 »
Not sure if its variable vane or not tbh. Should have had a look at the old one before I binned it.  :-\
Will inspect pipes, vac connection etc. first and go from there.  :y
Raeturbo
  • South Wales
« Reply #23122 on: 11 December 2021, 18:58:32 »
What’s the reg👍
Migv6 le Frog Fan
« Reply #23123 on: 11 December 2021, 19:11:52 »
CV59 PDK. I assume getting rid of carbon build up in the turbo means removing and dismantling the bloody thing ?
Could always try spraying some oven cleaner or similar in there I suppose.  :-\
Raeturbo
  • South Wales
« Reply #23124 on: 11 December 2021, 19:55:55 »
Ahh it’s a kp35 so no vnt
Migv6 le Frog Fan
« Reply #23125 on: 11 December 2021, 20:07:03 »
Just watched a couple of youtube videos where cleaning foam is sprayed into the turbo to clean it, so that might be a possibility.
Will check other stuff first though.
Cheers.  :y
« Reply #23126 on: 11 December 2021, 20:10:08 »
This has a dial and its rubbish, would be bearable if the voice command was half decent. (Its not). Entering nav destinations is painful, browsing songs and stations similar. Works far better if you use Smartphone projection but that often fails to connect
« Reply #23127 on: 11 December 2021, 20:12:33 »
 if the voice command was half decent. (Its not).  ....
Mine is sh1te too!  ;D
Raeturbo
  • South Wales
« Reply #23128 on: 11 December 2021, 20:12:49 »
Cheers.  :y
                Aye but that’s for the VGT type check your intercooler they sometimes swell and leak on those cars.
« Reply #23129 on: 11 December 2021, 20:43:44 »
Cheers.  :y
Presumably you remove the turbo first before spraying oven cleaner into it?  ???        :D ;D
