Author Topic: So what have you done to your car today?  (Read 7094641 times)
0 Members and 46 Guests are viewing this topic.
« Reply #23130 on: 11 December 2021, 21:21:23 »
Or whilst it's running, and nice and hot :D
  • Online Online
    • Grandland 1.5 diesel
« Reply #23131 on: 11 December 2021, 21:32:38 »
Yes, it tells you to warm the oven before using. Spray it straight in at max revs and report back, Albs.
Diesel till I die
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #23132 on: 11 December 2021, 22:17:48 »
Sounds like a plan.  :y...................wonder if the insurance would pay out.  :-\ ;D
« Reply #23133 on: 11 December 2021, 22:37:46 »
It would probably give little Pierre a good de-coke!  :y
« Reply #23134 on: 11 December 2021, 22:46:48 »
... It was at that point that I realised that the handbrake had failed.
Migv6 le Frog Fan
  • Online Online
« Reply #23135 on: 11 December 2021, 23:16:17 »
Watch this space.  :-X ;D
« Reply #23136 on: 12 December 2021, 18:40:19 »
 if the voice command was half decent. (Its not).  ....
Mine is sh1te too!  ;D
You need to speak in 'Allo! 'Allo! Gestapo German for it to understand.
The Jag one actually works really well, but obviously I speak like the Queen.  I guess DTM's car, being much newer, he has to speak fluent Hindi English.
    • 530D M Sport, 330i Coupe
« Reply #23137 on: 12 December 2021, 20:28:14 »
Another oil and filter on the project.... only did it 6 weeks ago  :o must stop driving it to Scotland every week  ;D
« Reply #23138 on: 12 December 2021, 20:30:15 »
I think the oil is due (by my schedule) on both of mine. But CBA won out ;D
speedy_ns
  • Novi Sad Serbia
    • Omega B 2.5 DTI
« Reply #23139 on: 12 December 2021, 21:35:20 »
Finally resolved diesel leak on 2.5 DTI.
Turns out that piece of rubber hose that goes from fuel filter to HPFP started to disintegrate. I couldn't find new peace so I had to fabricate it, and it works. I cleaned EGR while I was there, now I have to resolve cold start problem in the morning. Glow plugs, relay or both probably..
« Reply #23140 on: 13 December 2021, 09:11:13 »
Assuming the DTi is a similar setup to the older 2.5TD, with the exception of common rail fuel delivery, the glow plugs are nice and easy. Worth having spare inlet manifold gaskets before removing the intake if it hasn't been off for a while, in case you year one, but all straightforward and easy :y
When I did my 2.5TD ones, it was during my lunch hour at work, and still had time for a quick bite and a brew :)
speedy_ns
  • Novi Sad Serbia
    • Omega B 2.5 DTI
« Reply #23141 on: 13 December 2021, 16:54:17 »
You are correct. Manifold was down couple months ago when HPFP decided to die.
Honestly, Bmw could make it simpler. I remember changing those on 2.3td Frontera, and it could be done on parking lot with one eye and one hand.
« Reply #23142 on: 13 December 2021, 17:48:32 »
Drove it to the Minor injuries unit in Horsham, who apparently can't be arsed to look at a deep cut, let alone dress it :-X
They suggested Crawley at 16.45 on a weekday. So belted it down to St Richards in Chichester. Because you know Crawley will say East Surrey due to TCV and too late to be seen.
Highlighted two issues... The front pads aren't happy and the gearbox needs about a litre of fluid to smooth the shifts out. Job for tomorrow* ::)
The cheapest R Class in the country is starting to look like a good idea :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23143 on: 13 December 2021, 18:22:34 »
Not got a first aid kit with a plaster in it DG  :-\
that's not good forward planning is it  :D
« Reply #23144 on: 13 December 2021, 19:18:52 »
I do, but it is almost as old as Tunnie and won't stop a bleed on blood thinners.
Besides, you can't use plasters any more in case wound is allergic :-X
Page created in 0.024 seconds with 20 queries.
