Author Topic: So what have you done to your car today?  (Read 6912896 times)
0 Members and 15 Guests are viewing this topic.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #23715 on: 03 May 2022, 21:07:02 »
 NO just raving normal hot rodder !! I like a challenge .
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #23716 on: 04 May 2022, 18:20:06 »
Serviced Mavis*. Or as much as I could... Found one of the holes was inadequately lubricated and so I'm now soaking it in lubricant to make it move more freely.
*The Civic. And it's a sticky brake slider. What did you think?!
    • Grandland 1.5 diesel
« Reply #23717 on: 04 May 2022, 18:22:53 »
Oh! I thought you meant a womans thingy  ;D
Diesel till I die
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #23718 on: 04 May 2022, 19:14:14 »
Made a ply template for door glass on the Austin and then started to work out how the hell the Omega window mech will fit , not to bad as happens but have to find something to attach it to the glass . Should have kept some glass back when I scraped the doner
From what I remember, the Omega drop glass uses plastic wheels in channels stuck to the glass.
That's just like a Mini, and the parts are readily available at a price that makes messing about with them pointless: LINK
countrywoman
  • worcestershire
    • skoda yeti
« Reply #23719 on: 05 May 2022, 09:05:22 »
Radiused oblong blocks on Omega and they need to fit snug in channel , trip to help yourself scrappy tomorrow to rip some door cards off!!!!!
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #23720 on: 05 May 2022, 09:34:13 »
I didn't think such places still existed due to elf n shafty?!
countrywoman
  • worcestershire
    • skoda yeti
« Reply #23721 on: 05 May 2022, 13:01:29 »
Harry Bucklands near Cheltenham , they remove all the fluids first before they get lined up. Full of French crap and Fiestas and Corsa's last time I went .
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #23722 on: 05 May 2022, 18:24:06 »
Replaced the spark plug tubes, did some engine cleaning and adjusted the handbrake on the Boxster.
Want to get it ready for MOT, and then the Omega is due oil and filters.
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #23723 on: 05 May 2022, 19:32:38 »
Ooo! Harry Bucklands. A good old scrapyard with plenty of cars and an extra bonus, all the cars are at ground level. ;)
« Reply #23724 on: 06 May 2022, 20:33:39 »
Off to Keighley tomorrow for the oil pickup seal change, can't wait. I believe Keighley is in the running for city of culture 2023. I've had a quick look on Google maps and found three supermarkets and sixteen curry houses within 15 minutes of the workshop.
Diesel till I die
« Reply #23725 on: 06 May 2022, 20:58:25 »
Did the next oil and filter change on the Alabama Mumsybus.
About 800 miles before the 5,000 interval I set myself, but new job next week is a 92 mile round trip so won't take long to hit the next 5,0000...
Only slight concern is that it takes 8.5 litres of oil and 7.25 came out... 250 ml every 1,000 miles isn't bad, but seems a lot.  :-\
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #23726 on: 06 May 2022, 21:21:16 »
Probably some left in the oil cooler, normally is👍
Laying a rubber road.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #23727 on: 07 May 2022, 09:09:59 »
Had a go at bleeding the brakes on the Austin, fronts blead fine but nothing coming out of rear at master. Piston must be stuck ,well it has been dry for a few good years. One last trick to try today if I can get a hand.
« Reply #23728 on: 07 May 2022, 15:07:59 »
Just got back. New oil pump, pick up and seal, timing belt and water pump, glow plug number 2 and air filter. Said try and keep the revs down and drive below 55mpg for about 500 miles. Yikes!  :o
Diesel till I die
« Reply #23729 on: 07 May 2022, 15:18:47 »
Better than selling it. :y
