Quote from: Migv6 le Frog Fan on 08 June 2022, 20:12:31
If one more person calls me fickin French............... >:( >:(
I know you're most definitely not ;)
French and Northern Irish.  Yeah, that explains it all ;D
Quote from: TheBoy on 09 June 2022, 12:16:10
OOOOOO......he don't like that, either. Apparently he's British.  ;D
Diesel till I die
Quote from: STEMO on 09 June 2022, 12:20:15
Sure he's not Fritish, or Brench? He protesteth too much methinks.
Actually, showing my ignorance here, Great Britain doesn't include NI, so does that mean that residents of NI aren't British? Or does British include all of the UK?
Quote from: TheBoy on 09 June 2022, 12:23:17
You'll have to ask Irish British Albs. I, too, thought that NI was part of the UK, but not GB.
A
He'll be along to educate us when he's finished fettling with Pierre. OOOOER Missus  ;D
Diesel till I die
Quote from: STEMO on 09 June 2022, 12:29:06
He does seem to spend an awful lot of time fondling with Pierre's bits...
Migv6 le Frog Fan
Looks like I shall be fondling Peirres bits no longer. Aux. belt has come off and found a new home wrapped very tightly around the crank pulley around and under the cambelt.
Set the cam pulley to the timing mark - presumably meaning valves are closed - and tried turning the crank. It gets to a certain point and wont go any further. Just get a sound of metal touching metal. So down the scrappy I reckon.
It seems the cam can be rotated 360 degrees, but the crank cant.  :-\
Will be driving the Omega very gently indeed, to work starting Saturday.  :'(
And yes, all citizens of the United Kingdom of Great Britain and Northern Ireland are British.  ;)
Whether they like it or not.  ;D................Im one of the ones more than happy to be so.  :)
Diesel till I die
Timing mark will just be the datum for belt fitting. I doubt there's any position where all the valves are closed.
Migv6 le Frog Fan
Ah, I see. I should have known that really.  :-[ ;D
So best way to tell is put the belt back on and try and start it I suppose ?
Quote from: Migv6 le Frog Fan on 09 June 2022, 18:13:07
Pierre lives. Vive Pierre!
Diesel till I die
Migv6 le Frog Fan
Actually, I should have said - see if it turns over using a socket on the crank pulley bolt.  ::) ;D
I have a feeling that it has expired though.
If it has I will pull off the new genuine turbo I put on it a few months ago. Ive even keep the Renault box it came in.
Might pull the Cat off while Im at it, and sell that separately too.
Raeturbo
Today... you should be very relived it's finally let you off the hook. Now then, buy yourself a nice little 1.6 16v Astra G  run about, you won't regret it👍
Laying a rubber road.
Migv6 le Frog Fan
If it does at least 50mpg and costs a three figure sum then point me in its direction.  :y ;D
Raeturbo
Three figures no problem but 35/40 odd achievable  :y
