Thought about washing it, following its holibobs last week.
Glad I didn't, as next door are having their outside woodwork sanded ready for painting. Dust city ;D
Quote from: TheBoy on 20 June 2022, 20:18:18
I might get the Albanians at Longford to do mine tomorrow. Desperately needs the bits of pigeon, bugs and Avgas washed off... Done almost 4,000 miles since its last bath :-[
Migv6 le Frog Fan
Quote from: Doctor Gollum on 20 June 2022, 20:07:29
Is the fuel pump belt driven?
It is indeed. Pulley next to the cam pulley. Its has been carefully set in the correct position, so cant see that being the problem.
Raeturbo
Laying a rubber road.
Viral_Jim
Quote from: Doctor Gollum on 20 June 2022, 16:04:49
Averaging 30 - 31mpg on my new commute without faffing around.
Not bad at all for a big AWD bus. :y
henryd
Quote from: Migv6 le Frog Fan on 20 June 2022, 18:15:01
Topped up the screenwash on the Omega and Boxster - that was it for the day.  ;D
Will probably revisit Pierre tomorrow if my patience is feeling strong.
Refitted cambelt and other bits a couple of days ago and it wound over on the starter without any worrying noises.
No sign of it trying to start at all though.
Sprayed a bit of brake cleaner down the air intake and it fired up and ran for a few seconds.
Fault code suggests a problem with fuel supply, and it does indeed behave as though its not getting any fuel.
Cant imagine why it has decided to do this when the cambelt apparently jumped a few teeth while it was ticking over though.  ::) ???
I know its common rail but is the pump timed ?
other rides
Raeturbo
Migv6 le Frog Fan
I have read that the pump isnt timed, but there is a dot on the pulley to line up with a certain point on the engine, which I have done when refitting the cambelt.
I would love to scrap the little bastard, but tbh cant afford to replace it unless I sell the Boxster, and I would really like to avoid doing that for at least another year.
Lizzie Zoom
Quote from: Migv6 le Frog Fan on 21 June 2022, 12:49:02
If its common rail then the pump is not timed, if its a clasic rotary or inline injection pump, then it is  :y
Raeturbo
Quote from: Lizzie Zoom on 21 June 2022, 12:49:35
Quote from: Raeturbo on 21 June 2022, 12:40:31
It's dead I tell you.....
The parrot is dead?............ ;D
                 Nice plumage  ;D
Lizzie Zoom
Quote from: Raeturbo on 21 June 2022, 13:34:28
                 Nice plumage  ;D
But are you really sure it is dead?  You know, really dead?......
;D ;D ;)
Quote from: Lizzie Zoom on 21 June 2022, 13:46:06
                 Nice plumage  ;D
;D ;D ;)
Well it has been eaten and the bones stewing for stock...
