dave the builder
Quote from: Doctor Gollum on 28 August 2022, 23:19:04
A nice, reliable Mercedes...  ;D
:o
you've spent most your spare time in the last 5 years fixing the 3 Mercs you've had DG  :P
Quote from: dave the builder on 28 August 2022, 23:26:56
:o
Maintaining is not the same as fixing as you well know, having spent the same time not fixing your fleet of Vauxhalls ;)
countrywoman
Still filling, rubbing and painting panels for the Austin. Will be soooooooo glad when its all painted as I hate body work. Then its back on the Omega running gear .
Quote from: TheBoy on 29 August 2022, 18:14:22
Too old for me.... ;)
Are you suggesting that modern Mercedes' are merely parts bin cars?  ;D
Diesel till I die
Quote from: STEMO on 29 August 2022, 18:57:06
Are you suggesting otherwise?
LC0112G
Woooohooooo - Elsie through the MOT for another year. Slight whinge about the handbrake reserve travel - but the handbrake has always been close to useless on it.
Quote from: LC0112G on 30 August 2022, 13:01:51
Always a good feeling.  Assuming you always use the handbrake, just a spot of adjustment needed ;).  Omega handbrakes are useless for doing U-turns in the road, but plenty good enough to work as a parking brake :)
Finally found out how long the fuel light stays on for :-[
Annoying it doesn't flash. On the plus side I was just about able to get it, sort of, out of the way.
Needs to go on a diet though, couldn't move it for trying.
Fortunately, it eventually restarted with a gallon added.  :-[
Also should be the last time it gets run that low as after this week my commute drops to about ten times a month rather than five days a week.
Looking forward to getting the car back this afternoon :)
Bit sad, I'm excited about a broken car turning up ;D
Car now on driveway.  Battery as flat as a witches tit, so suspect thats shagged
henryd
Quote from: TheBoy on 31 August 2022, 13:31:19
What made it break down in the first place ?
other rides
Quote from: henryd on 31 August 2022, 14:09:45
Have a look at warranywise's reliability index.
Diesel till I die
That'll be all that electricity you insist on cramming into the poor thing.  ::)  :P
