Cleaned and painted the front calipers on the V70. Anything is an improvement on rust!
Picked up my wheels from the refurb place and fitted them back on the Monsit and I'm very pleased with the result.  :y
I had them done black, which I have a feeling I'll regret as time goes on as every little scratch and scuff will stick out like a sore thumb.  :-\
Quote from: Sir Tigger KC on 17 March 2023, 19:14:24
Do they hold air now?
Quote from: Doctor Gollum on 17 March 2023, 19:22:38
I'll let you know tomorrow.  :)
Quote from: Sir Tigger KC on 17 March 2023, 19:34:16
countrywoman
Had "fun" fitting the down pipes in the Austin, tried to remove the lambda sensor from o/s to make it easier. No bloody chance as its most likely the original from 96. Got it to move just over 1/2 turn with heat but that was it, didnt have enough heat.
All cables hooked up to engine now, just need to work out the 2 cut off wires I left sticking out. One black/white and the other black/blue, think one might have gone to the reverse switch? from memory. Will have to do a pin test.
The black and white one is the reverse switch ;)
countrywoman
Yes I was sure about that one, only needed on auto I suspect.
countrywoman
It goes to air con, not that this ex plod car had any(universal loom)
The Mondeo's refurbed wheels are holding pressure....  so far!  :y
But now the windscreen washer pipe has popped off the pump again!  >:(
One step forward.....  ::)
dave the builder
Quote from: Sir Tigger KC on 18 March 2023, 18:12:54
you should have done it right the first time  ::)
or didn't you have cable ties and duct tape with you  :D
Quote from: dave the builder on 18 March 2023, 19:27:31
I thought a dab of glue would do the trick.  :-\
Viral_Jim
Quote from: Sir Tigger KC on 18 March 2023, 21:24:13
Could mean there's a blockage somewhere? Surely you don't get that much back pressure out of a washer pump?
Quote from: countrywoman on 18 March 2023, 09:10:45
You suspect incorrectly ;)
countrywoman
In that case before I cock it up what does it do?
