Viral_Jim
tigers_gonads
Popped 4 reconditioned injectors into the CR-V
Now starts instantly and it much MUCH smoother to drive.
Getting the injectors coded into the ECU on Friday so should be much better on fuel.
Now got to look into this rumbling noise / clutch slipping business  :'(
Buy a Honda CR-V they said .......
Lovely and reliable they said .......
You won't regret it they said ......
'dangle berries'
Hondas are reliable, and scheduled maintenance is well thought out and affordable just like most other Japanese cars. But if you manage to break one.....
It could be worse, you might have been daft enough to buy a Mitsubishi ;D
tigers_gonads
Quote from: Nick W on 19 April 2023, 12:55:04
Broke the Omega last year and had to move quick.
Lads got a Mk8 Civic with the same donk in it and other then the stupidly sensitive steering, I actually like the car.
Me and the missus are not getting any younger and i've got to admit its bloody comfy and I love stepping into / out of the thing but look at the omega sat there everyday and ask myself the question .......  then the wife cracks my across the head  :-[ ;D
Bought it from a dealer at the time these things where going up in price by 100 quid a week  (first time ever) and got my pants pulled down  :'(
It was supposed to be fully stamped up but the more I look into it, somebody had been playing with the stamp and ink  >:(
Just my luck the past few years  ::)
Migv6 le Frog Fan
Not usually  the most exciting things to drive, but the build quality is miles ahead of any European stuff.  ;)
Quote from: Migv6 le Frog Fan on 19 April 2023, 15:12:35
I might go for one when my Astra dies. Diesel, of course  :)
Diesel till I die
Initial potentially yes (although the Japs tend to steer away from the latest tech and settle on the safer bet, proven, last gen, which is what keeps the quality a bit higher) but, after about ten years this drops off a cliff and then they can get very problematic.
countrywoman
EGR delete unit finished, now the bonnets back on the Austin its fart around with the intake pipework again. Checked clearance to bonnet with scrunched up foil and under the cross brace it was 3mm---------
Quote from: countrywoman on 19 April 2023, 17:11:35
...... Checked clearance to bonnet with scrunched up foil and under the cross brace it was 3mm---------
Loads of room then  ;D ;D
Raeturbo
Quote from: STEMO on 19 April 2023, 16:17:41
You'll have a long wait they don't die
Laying a rubber road.
johnnydog
Took two of the Omegas for MOT's (the 2.6 and the 3.2 saloon) - both passed with no advisories :y They got a few complimentary comments as well from other admiring customers - happy days!
tigers_gonads
Quote from: Marks DTM Calib on 19 April 2023, 16:29:06
Tell me about it
Mechanically its seems very well thought out and put together but little things like nuts that are made of shite steel corrode and round off with a hard stare.
Makes what should be a easyish job a ball ache.
And the parts ain't cheap either  :'(
dave the builder
Quote from: johnnydog on 20 April 2023, 01:17:51
Congratulations on the MOTs  :)
from your posts it's obvious you look after your Omegas very well  :y
johnnydog
Quote from: dave the builder on 20 April 2023, 12:22:33
Cheers Dave :y
It wouldn't be the first time that my wife comments that my cars get better looked after and more attention than she does.... ;D
