Also did you swap the sensor to the OSF to see if the fault moved :-\
Quote from: Doctor Gollum on 07 July 2024, 19:31:00
The thought was there, but H had done brunch, and there was qualifying and footie to watch. So, errr, no!
Doh.
Although in the face of such distractions I totally sympathise  :y
Rangie
Collected the caravan & all set for a few days in Yorkshire, it's a hard life this retirement lark..😂
Quote from: Rangie on 08 July 2024, 12:42:26
Lucky you! Hopefully the sun will make an appearance :)
Rangie
#26510
Quote from: VXL V6 on 09 July 2024, 18:57:54
It would be nice if it did , pretty wet at the showground today, but plenty of pubs & restaurants in the area to drown our sorrows, back in Spain at the end of the month plenty of 🌞🌞🌞then, ate in Harrogate tonight at The Fat Badger excellent meal.
Battery charger installed. Fly lead hard wired as per Merc instructions for charging the consumer battery.
Only gripe is the length of the cables... The connection to the charger is relatively short so have had to place the charger in front of the radiator, bonnet still latches, and the mains plug is just inside the garage door.
Seems to be charging ok, and the car isn't complaining so that's something. Can just about see the display through the grill.
Sat on my backside in the Mondeo while the car wash did it's thing and washed all the seagull shite off.  :)
Quote from: Sir Tigger KC on 13 July 2024, 20:06:48
Lazy sod.
Bucket.....sponge....fairy liquid ( or similar )......job done.
Plus you get an upper body and cardio workout thrown in for free. 8)
Then crack open a well deserved beer. :y
Quote from: Field Marshal Dr. Opti on 14 July 2024, 13:57:37
Lazy sod.
Yes.  ;D
Quote from: Sir Tigger KC on 14 July 2024, 14:11:32
Lazy sod.
Yes.  ;D
I believe your elderly scouse uncle pays a couple of illegals to wash his car.
Keeps the costs down. ::)
Quote from: Field Marshal Dr. Opti on 14 July 2024, 15:55:24
Lazy sod.
Yes.  ;D
£10 for a swarthy southern European to rub a wet chamois all over my car. Hardly cheap.
Diesel till I die
Migv6 le Frog Fan
Went out to change a tail / stop bulb on the roller skate, but much to  my surprise I have run out of double filament bulbs.
Then tried to find out why the interior light, vanity lights and puddle lights arent working on the Boxster. Didnt find anything obvious.
Gave up at that point and took the Tortoise for a walk around the garden, so at least that used up an hour of my time, while swmbo was watching a couple of blokes on telly, playing a game of bat & ball. ::)  ;D
Save some energy for the Golf later ;D
Wifeys grandland had its first MOT yesterday. Out of warranty, so phoned Vx for a quote. £187 for 12 months for the top one( gold or whatever). Not bad. Oh...£200 excess, still not bad.
Diesel till I die
