Rangie
Had a ride out to Burghley House with wifey & the youngest Grandson, took the RRS the more I drive it l realise what a bargain I got for £7,000 five years ago power & comfort great combination 👍
Migv6 le Frog Fan
Took the Boxster for MOT. Initially failed on a sidelight not working. Changed the bulb but it made no difference.
Found that the connector into the rear of the headlight wasnt seating properly, so remedied that and got a years ticket.  :)
Raeturbo
Took the Jag out for a nice airing yesterday, its  performing perfectly and has done for at least six months 😱😱 here's hoping I haven't jinxed it now😳
Laying a rubber road.
Quote from: Raeturbo on 23 July 2024, 20:29:51
the Jag
//TheBoy looks on with envy....
Took the Proper car out for a walk to knock some of cobwebs off it. Being plugged in seems to be keeping on top of the batteries. Which is nice.
Raeturbo
Quote from: TheBoy on 24 July 2024, 17:13:33
the Jag
No doubt🤣 but to cheer you up I need an Ecu  from an evo 5 or 6 now so as I can remap as my 2008 moates ostrich emulator is getting corrupt every now and again. Needless to say it's going to be a tasty financial feast🙁🙁
Terbs
Put two rear brake cylinders on the wife's puddle jumping Micra.
Replaced the filter in the EGR on hers.
Investigated the oil misting from the dipstick tube on hers - turns out it was actually a pipe from the (other) EGR to intake wasn't sealing, and blowing a little sooty oil.  Looks like last time I removed that I must have dislodged the o-ring on refitting, so schoolboy error on my part.
Investigated the regular "Bonnet Open" errors on hers - cleaned out all the old sticky grease from the latch that side so the switch lever was not getting stuck.
On mine, gave it it's first run since fitting the NSF suspension sensor bought from a real dealer at great expense - £170 - because the ebay shite was, well, shite.  Trip to Suffolk and back presented only one error. Low fuel.  Which was very, very factually correct ;D
Washed my highly desirable, and extremely valuable classic Vauxhall, with a bucket of cold water and a sponge.
If the weather is warm and sunny come 29th July 2025 I shall do the same again. :)
Quote from: Field Marshal Dr. Opti on 29 July 2024, 13:13:04
That's assuming you're still here of course.    :-\   :)
Quote from: Sir Tigger KC on 29 July 2024, 13:47:15
All of us only have 'this moment in time' :)
None of us can guarantee we will see another day.
I wonder how many people drive to work each day without a care in the world but never return.
Quote from: Field Marshal Dr. Opti on 29 July 2024, 14:22:11
About 1500 people a day die in the UK, and about 76% of the population are in work, so quite a few.  :-\
You're lucky you survived the exertions of washing your classic car today!  :)
ronnyd
What a shitty way to treat a desirable 'modern classic'. Your words, no one else's.  :)
Quote from: Sir Tigger KC on 29 July 2024, 15:54:25
I always treat myself to a bottle of beer ....5% ABV lager. :y
Quote from: ronnyd on 29 July 2024, 17:04:32
Tis true. :D
I bet even the illegals that STMO pays have less grit in their sponge. ::)
